ReMan
posted on 2/3/12 at 10:56 PM |
MNR Reverse box mounting
Anyone got a picture of how the MNR reverse is mounted onto the chassis, on an MNR or other
I will be starting my winter upgrades this weekend and I have one to fit into the MK
www.plusnine.co.uk
big_l
posted on 2/3/12 at 11:33 PM |
it mounts on a little bridge that raises it up about 6 inches.
you will prob find a pic on my blog...
Check out my blog mnrvortxhayabusa@blogspot.com
The Venom Project
posted on 3/3/12 at 02:28 AM |
Mine was a Quaife box, but the mount is the same I think, Mine is the gold coloured box onboard a plate welded into the frame by MNR
[Edited on 3/3/12 by The Venom Project]
It's not that i'm lazy, it's that I just don't care.....
Pezza
posted on 3/3/12 at 07:59 AM |
We mounted ours on a 5mm plate, which was then bolted to the gb mounts and another bar welded in further back, worked a treat in our Indy
Sorry for the crappy pic, it's the only one I could find from during the build.
[Edited on 3-3-12 by Pezza]
You couldn't pwn your way out of a wet paper bag, with "PWN ME!!" written on it, from the "pwned take-away" which originally contained one
portion of chicken tikka pwnsala and the obligatory free pwnpadom.
ReMan
posted on 3/3/12 at 09:06 AM |
Ahhh you had car engine gearbox mount somewhere down there
www.plusnine.co.uk
ReMan
posted on 3/3/12 at 09:08 AM |
Cant quite see it in the picture but is the plate sitting on, or raised above the bottom chassis tubes?
www.plusnine.co.uk
The Venom Project
posted on 3/3/12 at 11:52 AM |
The two centre parts of the frame front to back support a section made by MNR, it raises it over the where you would run, brake and fuel lines, you
can bolt it in from underneath, I know my Quaife had 4 bolt holes on each corner, I suspect the MNR one in the other picture is the same, The MNR
reverse box is the one to buy unless you have already bought one, as it has no drag, the Quaife box was very tight once in reverse mode, the MNR one
has no friction. Both cost around the same. Sorry I don't have a better pic either.
Pezza
posted on 3/3/12 at 12:26 PM |
Yeah it was going to be a zetec install in the beginning.
ReMan
posted on 3/3/12 at 12:57 PM |
Yes it's an MNR one I picked up, so I'm goinf g to strart stripping the car this weekend to look at fitting it
www.plusnine.co.uk
PAUL FISHER
posted on 3/3/12 at 01:43 PM |
I will just pop in the garage and take a few pictures of my MNR box in the Aries, Ive got the tunnel covers off after fitting my paddle shift.
PAUL FISHER
posted on 3/3/12 at 02:52 PM |
Here you go, this is the Aries/Stuart taylor mounting and propshafts.
![](/galpreviews/MNR BOX ARIES BRACKET2.jpg) ![MNR BOX ARIES MOUNT](/gallery/MNR BOX ARIES BRACKET2.jpg) MNR BOX ARIES MOUNT
PAUL FISHER
posted on 3/3/12 at 03:01 PM |
And
[img]
![](/galpreviews/box1 small.jpg) ![mnr reverse box in a Aries](/gallery/box1 small.jpg) mnr reverse box in a Aries
[/img]
ReMan
posted on 3/3/12 at 05:26 PM |
Cheers for that, thyre great
I havent even got he panels off yet, that's Sunday, but I was picturing it being too low If I just sat a plate across the bottom chassis/tunnel
rails.
I think these confirm I need to look at raining it on sqare tub our similar to a better working height and to keep the props at a better angle
www.plusnine.co.uk
