<<  1    2    3    4  >>
Author: Subject: PRO-BLADE-TURBO-COMP. RE-BUILD
welderman
posted on 10/7/12 at 08:56 AM Reply With Quote
This will be a start of my re-build diary, im not good with words but will take lots and lots of pictures .
First up is how this car started life as i once knew and how it once looked, some of you might know the car already as it was once for a short period owned by a fellow member on here, ive pinched this description of the car from a post and theres a picture of it too.
Procomp LA Gold
Life started out for this car as a 2002 car that's been road-registered, but used predominantly for sprinting.
2.0 16v Vauxhall XE engine
QED 420 Cams
Up-rated Con-Rod Bolts
Twin Webber 45's
MBE Programmable Ignition
Tony Law Exhaust
Modified sump
Custom Ali Flywheel
5˝" Twin Plate Alcon Clutch
Circa 210bhp
TranX Close-Ratio Straight-Cut Clubman Box
4.4:1 Diff
4-pot Alloy Alcon F3 Front Calipers
2-pot Alloy Alcon Rear Calipers
Floating Discs All-Round
Fully Caged
This is a picture of the erm car after it was delivered. The rest of the car was in boxes , it did not however come with an engine as i had already had one from a previous build.
All comments most welcome good or bad as i go along.
[Edited on 10/7/12 by welderman]
Thank's, Joe
I don't stalk people
posted on 10/7/12 at 09:09 AM Reply With Quote
Not sure it suits those new yellow wheels Joe... you may have to lengthen the wheelbase a little too!
It's Evolution Baby!
welderman
posted on 10/7/12 at 09:24 AM Reply With Quote
rear wheel steering too
Thank's, Joe
welderman
posted on 10/7/12 at 09:36 AM Reply With Quote
Now sat in its home for the build.
Bear frame
Bear frame
Now time to find where was best to fit the engine, Honda Fireblade 919, with turbo.
Engine position ???
Engine position ???
Make shift prop
Engine position ??
Engine position ??
After a bit of moving around and a few blocks to get it right i proceded to make up a frame for it and re welded some bottom mounts to the frame.
Thank's, Joe
locoR1
posted on 10/7/12 at 10:35 AM Reply With Quote
Subscribed keep the pictures coming Joe
Will this be a trackday toy or is it going back on the road?
Check out my CB500T Cafe Racer build diary
imp paul
posted on 10/7/12 at 10:55 AM Reply With Quote
awesome joe it looks cool mate
BigLee
posted on 10/7/12 at 11:11 AM Reply With Quote
That cage isn't high enough for me
welderman
posted on 10/7/12 at 11:33 AM Reply With Quote
Trackday toy, but will get it an MOT too
Lee you could fit in it, but your head might pop up OVER the cage
Thank's, Joe
welderman
posted on 10/7/12 at 11:52 AM Reply With Quote
Dinner time so bit more update
engine sent to Andy Bates as back in the day i killed the gearbox , only had 1st, 5th and 6th left lol.
Scrounged a few old gearboxes to try and keep cost down but ended up having another fitted by Andy as it made more sense.
While the engine was on holiday, spun the frame round and started on the bottom, hammered the original ally floor back into shape, filled in some holes in the ally floor and a few in the frame and made a start with the rivits and sikaflex.
Welded ally floor
Welded ally floor
Thank's, Joe
D Beddows
posted on 10/7/12 at 11:55 AM Reply With Quote
Been looking forward to this
Dangle_kt
posted on 10/7/12 at 12:21 PM Reply With Quote
looking good joe!Keep up the good work!
Proby
posted on 10/7/12 at 12:49 PM Reply With Quote
This will be interesting, make sure you post pleny of pictures! I'm subscribed!
welderman
posted on 10/7/12 at 01:35 PM Reply With Quote
Floor fitted and made a start on the front and rear wishbones, fitted all new bushes purchased from Matt at Procomp .
ally floor on frame
ally floor on frame
Also fitted the massive huge Alcon callipers and disc’s.
offside front.dsic and caliper
Slotted the diff in but this was going to come out at some point as i wanted a 3.54 ratio.
Thank's, Joe
PAUL FISHER
posted on 10/7/12 at 02:56 PM Reply With Quote
Looking good Joe, love the Alcon brakes, I will be watching the rest of the build with interest now
welderman
posted on 10/7/12 at 02:59 PM Reply With Quote
Thanks Paul, they are mahooosive those things
quick brew so a few more pictures
Well a bit more bashing later !, managed to flatten all the inside and outside ally panels read to re fix into place.
Made a start on the brake lines too &#61514;
Couple of pictures of the footwell’s
driver footwell cylinders
drivers and passenger footwell
passenger footwell
passenger footwell
Tack welded a small bracket to the frame so i could put a “T” in for the brake switch. I must not forget to weld it up !!!!!!!!
cylinder and T
cylinder and T
Thank's, Joe
Steve Hignett
posted on 10/7/12 at 06:41 PM Reply With Quote
Lookin great so far BJ, but what's with all the gay Ali?
welderman
posted on 11/7/12 at 07:12 AM Reply With Quote
Gay Ali hmm, im having to use it to keep costs down and use up as many old parts of the car i possibly can
Thank's, Joe
welderman
posted on 11/7/12 at 07:18 AM Reply With Quote
As the original nose cone is quite a bit battered looking ive opted to fit another one instead.
Just trial fitted for now, dont want to cut it just yet
oh go on, and another
hows that Mr H
Thank's, Joe
Steve Hignett
posted on 11/7/12 at 08:08 AM Reply With Quote
looks alllrrriiiiiiighttttt............
welderman
posted on 11/7/12 at 12:00 PM Reply With Quote
Staying on with the carbon theme just for a while, i managed to get hold of some carbon fiber sheets and set about panelling the sides of the car, using the old ally ones as templates as there are 100’s of holes in each one.
Thank's, Joe
Steve Hignett
posted on 11/7/12 at 12:39 PM Reply With Quote
Lookin good matey
PAUL FISHER
posted on 11/7/12 at 12:42 PM Reply With Quote
Ooh all that carbon fibre, your just showing off now
welderman
posted on 12/7/12 at 07:41 AM Reply With Quote
Thanks for all your comments so far, there will be a 2 week break now, im off on holiday
Thank's, Joe
needforspeed
posted on 24/7/12 at 05:54 PM Reply With Quote
looks fantastic!
welderman
posted on 3/8/12 at 09:56 AM Reply With Quote
Back from holiday :(
Righty, ive been back from my holidays for a week &#61516;
Its so hard trying to get back into working, i need to win the lottery .
As you can see i have a bit of a carbon fettish, could be something to do with hanging around with a mate of mine, you know who you are.
Any how, back onto the build, after trawling the tinternet for what seemed ages i found a live axle 3.54 crown and pinion.
I stuck a bid on it and hay ho won it on ebay .
So then set about collecting it from Sheffield. Gave TommyP a ring and we set off with the my kids and on our merry way we traveled, nice drive over the Woodhead and back .
sheffield trip for diff
After a few days i decided to take the live axle appart !, first time for everything.
Then noticed i needed some new parts, bugger.
Ordered a spacer tube and some new bearings and waited.
After a bit of looking around i down loaded some destructions and managed to strip the diff and rebuild it after a few hours.
Diff rebuild.........
Diff rebuild......
Diff rebuild......
Diff rebuild....
Diff rebuild....
Diff rebuild...
Diff rebuild...
Diff rebuild...
Diff rebuild...
I only have myself to blame if it breaks
Thank's, Joe
<<  1    2    3    4  >>
