maccavvy
posted on 30/5/13 at 08:48 PM |
Carb jet info required.
Finally got my fireblade carbs running ok, once I found the air leak.
Its on the standard jets which are 120 ive been recommended to go to 130,untill I get it for a rr session but which bit is the bit I need to
change
http://farm8.staticflickr.com/7043/6908661532_5cc989d354_z.jpg
the main is the top screw on this pic. but do I simply change the screw bit or the hexagonal bit it screws into as well.
cheers in advance
Understeer , when the front hits a wall
Oversteer, when the back hits a wall
Horsepower ,how fast you hit the wall
Torque ,how far you take the wall with you
rick1962uk
posted on 30/5/13 at 09:37 PM |
you just need to change the screw part not the hex have you moved the engine breather from the airbox to a catch tank as that will make a few more hp
maccavvy
posted on 31/5/13 at 07:35 AM |
cheers dude. engine breather has been in a catch tank since day one.
now to get jets fitted then rr session.
