Plunky
posted on 13/5/17 at 07:56 AM |
Zetec Flywheel Bolts
Morning all,
With regards to the flywheel bolts on a 2.0 Zetec (Blacktop).
I know these require a sealant when fitting, to prevent any leaks.
Three questions;
1. Can you reuse the bolts?
2. What sealant should be used when fitting the bolts? Loctite?
3. Best way to lock the engine to torque up the bolts?
Liam
SJ
posted on 13/5/17 at 10:49 AM |
Loctite threadlock is what I used on mine. There is nothing to seal, you just need to stop the bolts vibrating loose.
I believe the standard bolts are not supposed to be reused. I ended up using ARP bolts as I couldn't get standard ones when I needed them. They
were £60 a set though.
posted on 13/5/17 at 12:35 PM |
I'd recommend arp bolts as well...
£60? That sounds harsh, have a shop around.. I've just bought a set for my rover v8 and they cost me £20.90p
obfripper
posted on 13/5/17 at 01:43 PM |
The reason for no reuse recommendation is the thread sealant/lock is preapplied to the new bolt as a hard compound, and after bolt removal will peel
away from the threads and not reseal if used again .
I have reused the old ones by dieing off the old sealant (using a split die opened up to not affect the thread), then reinstalling using stud grade
loctite applied to the bolt.
The bolt is not torqued to yield in original use, so should be mechanically ok for reuse.
Dave
SJ
posted on 13/5/17 at 03:22 PM |
I wanted to get the engine in that day and happened to be passing Burton Power. They aren't the cheapest!![](/images//smilies/sad.gif)
SJ
posted on 13/5/17 at 03:25 PM |
It was 10 years ago when I did mine so perhaps I'm remembering wrong with the suggestion of Loctite. The bolts will come with instruction on how
to install though.
obfripper
posted on 13/5/17 at 04:02 PM |
It's only the oe fitment bolts that have the preapplied threadlock compound, uprated arp bolts have to be installed with loctite to their given
specs.
On you last point, the cheapest way to lock your flywheel is a small length of angle iron bolted down to a bellhousing mounting hole, with the edge
engaged with the ringgear.
It's only iirc 60nm so shouldn't take too much effort to tighten, using a 6 point socket with a shallow chamfer will help to prevent the
socket slipping off.
Dave
Plunky
posted on 14/5/17 at 03:06 PM |
Thanks for all the advice.
dhutch
posted on 5/6/17 at 10:01 PM |
Sounds reasonable. While an important application, I don't expect the grade of thread lock used in overly critical?
Sounds a cunning plan, although surely even if the bellhousing is already off the gearbox, limits access if you fit it to the engine to undo the
flywheel?
That said, as yet I have failed to think of a better plan, certainly as my impact gun is playing up.
Daniel
obfripper
posted on 5/6/17 at 10:40 PM |
I was meaning on the block side mounting holes for the bellhousing, you also could use a double ended ring spanner between the bolt hole and one of
the clutch mounting holes to hold the flywheel from turning, or get posh and make a strip of steel like this to do the same.
https://www.evomoto.com/article_images/steps/step_419.jpeg
I would use a stud grade of loctite as it is thinner and will flow round the threads better to give an oil tight seal, normal grade would probably be
ok but may want applying to the hole as well as the bolt to ensure full coverage of the thread.
Dave
dhutch
posted on 5/6/17 at 11:09 PM |
Ahhh, late at night... ... That makes so much more sense.
dhutch
posted on 8/6/17 at 12:00 PM |
Random question as its not in front of me right now, but what size is the head?
I know its a thin-head but just wondering what size socket the job needs and I'll order one to grind flat.
Daniel
SJ
posted on 8/6/17 at 04:10 PM |
Pretty sure they are a 17mm socket. Why do you need to grind one?
posted on 8/6/17 at 05:38 PM |
quote: Originally posted by SJ Why do you need to grind one?
Most if not all sockets are rounded off at the opening. Since op is saying the bolt head is thinner than usual, grinding off tbe curved edge will
increase the contact area of the six flats.
SJ
posted on 8/6/17 at 09:24 PM |
I see the logic but there's no need if you have some decent sockets.
dhutch
posted on 9/6/17 at 01:27 PM |
In rushing in the evening after work I've half rounded one of the heads, so for the sake of £6 for a socket thats not part of a set, should
hopefully come out without complications tonight.
Daniel
[Edited on 9/6/2017 by dhutch]
dhutch
posted on 9/6/17 at 01:28 PM |
Daniel
