ArAKern
posted on 29/10/17 at 06:47 PM |
Heat shielding Phoenix side pods
Just wondering if anyone has lined their side pods to protect them from exhaust heat?
or is air flow sufficient this if for a road car so sitting in traffic a possibility....
(just about to paint them and do not fancy it peeling off first trip out)
adithorp
posted on 29/10/17 at 07:22 PM |
It's common to line the pod with heat protection. My Fury pod is lined with this sort of stuff using a high temp contact adhesive...
https://www.merlinmotorsport.co.uk/p/glass-cloth-150mm-x-1000mm-aac-150
Also worth noting that wrapping the headers and exhaust isn't regarded as a good idea as it keeps the gas temp very high and any leaks can then
set fire to the pod (it's happened to a few).
http://jpsc.org.uk/forum/
tims31
posted on 30/10/17 at 06:14 AM |
Yep, same as Adi
Side pods lined with heat shield matting and does the job to protect it from too much heat.
See herehttp://www.martinsfurybuild.co.uk/2016.html#nov_2016
Build: http://www.martinsfurybuild.co.uk/
ArAKern
posted on 30/10/17 at 11:50 AM |
Is the opinion to line the pods completely or just a section where the exhaust silencer is?
Trying to cut costs as I am still recovering from getting quotes for painting 4 sections of fiberglass
(just been a cheap skate having a v6 need to do both pods even with the cheapest material works out to £120+)
tims31
posted on 30/10/17 at 03:28 PM |
I bought my matting from CBS about 2 meters and it was nowhere near that expensive.
Angel Acevedo
posted on 30/10/17 at 04:04 PM |
Wouldn´t it be cheaper to have screens on the silencers instead?
To create air gap.
This is the way manufacturers shield exhaust manifolds in engine compartments.
My 2 cents.
adithorp
posted on 30/10/17 at 04:33 PM |
I'd say line the whole thing and do the side panel as well or you'll feel the heat in the car... well you will anyway but that will reduce
it abit. Sorry, I just linked to the first site I checked. There's plenty of it for sale cheaper elsewhere.
Angel, you're right but tin tops exhausts usually have a lot more air flow (and space) around there exhausts.
Be sure to open the front and rear of the pod to get air flow. I also put holes along the bottom (out of sight) and found that meant the pod
didn't get as hot when stationary because it allowed a flow of cool air in from below and the hot air out the ends
