dunk3
posted on 30/5/18 at 04:22 PM |
Reverse switch /button
Hi all , what have you all used to switch your electric reverse gear on, I. E switch or button and does it have to be heavy duty. Any links to the
switches or buttons would be helpful.
CosKev3
posted on 30/5/18 at 05:29 PM |
If you want to have the switch wired direct to the reverse you will need the likes of a starter or horn button,heavy duty.
If you want to wire in a relay that the switch activates you can use whatever switch you fancy then.
I've used a starter button with a rubber cover on it
CosKev3
posted on 30/5/18 at 05:35 PM |
http://www.halfords.com/workshop-tools/garage-equipment/fuses-electricals-fixings/halfords-heavy-duty-push-switch-hef358
I've used one of those
Hopley89
posted on 30/5/18 at 08:30 PM |
I wired mine from the Neutral Light to a switch on dash (with small red led under the switch) to a push button
under the hand break leaver
The small led is so i know it’s activated on dash when in neutral as i don’t want to keep the reverse light on if sat at Traffic light in neutral!!
ReMan
posted on 30/5/18 at 09:13 PM |
Well if its working thats great, but I think a starter , even a small bike one will take a lot more than 16 amps?
Though possibly less in this application that spinning an engine?
www.plusnine.co.uk
CosKev3
posted on 31/5/18 at 03:45 AM |
It's only firing the solenoid though,the main power is on the wire direct from the battery.
Makes no difference if it's spinning over a 1ltr bike engine or trying to reverse a 600kg car the solenoid won't draw any more current
whatever
[Edited on 31/5/18 by CosKev3]
JekRankin
posted on 31/5/18 at 09:10 AM |
Wired mine through a toggle switch with an inline 10A fuse. No problems so far. The switch is an Apem 600 series and is rated at 15A if I remember
correctly.
dunk3
posted on 31/5/18 at 03:54 PM |
Thanks for the replys guy's, think I will go toggle switch with led light to tell me it's on and 20amp push button to engage reverse .
ReMan
posted on 31/5/18 at 08:58 PM |
whatever
HA HA
What a t1t, it was early and I'd forgot all about that most modern CAR starters have integral solenoid,
www.plusnine.co.uk
