locoboy
posted on 12/5/05 at 06:35 PM |
How to EMPTY a gas cylinder
Chaps,
I am wanting to COMPLETELY empty a propane cylinder so i can cut it in half!
I have depressed the valve on the top and i can no longer hear the 'pffffft' you normally get when there is some pressure in there.
Does anyone know it the brass valve will screw off the cylinder? if so is it right or left hand thread?
I tried to drill a 1mm hole in it going nice and slow with WD40 as a lube but i made pretty much no progress, its really hard steel i think.
Locoboy
bigandy
posted on 12/5/05 at 07:08 PM |
Not sure about the thread, but when you do get access to the inside of it, the best way to completely evacuate it of all gas is to fill it completely
with water.....
Dammit! Too many decisions....
NigeEss
posted on 12/5/05 at 07:28 PM |
Not sure either if it screwed, but if it's brass then drill that as it shouldn't spark.
longwayoff
posted on 12/5/05 at 07:57 PM |
Must be a blunt drill I drilled one and used it as a compesed air tank with no hassle
And yes waters is the best way of getting the gas out but I suppose chucking it on a bomb fire might work as well but then I expect it would also put
an end to you trying to drill it and every thing else
Glan Noye
posted on 12/5/05 at 08:28 PM |
Please be careful.Read this http://www.thisisbournemouth.co.uk/dorset/poole/news/POOLE_NEWS_NEWS0.html Apparently this happened while an oxygen
cylinder was being cut up for scrap.The explosion was heard miles away.Glan.
907
posted on 12/5/05 at 08:31 PM |
I'll second that.
I submerged mine in water and drilled it with a battery drill. (240v and water don't mix)
The water level was about 25mm above the place I was drilling and the valve had been left open an hour or more.
But when the drill broke through there was still enough pressure inside to soak me as the gas bubbled out.
The neighbours were highly amused, watching from behind a wall. Chickens!
Paul G
Russ-Turner
posted on 12/5/05 at 09:02 PM |
Sounds like a right mess.
mangogrooveworkshop
posted on 13/5/05 at 12:05 AM |
email that to the darwin awards people they love those stories
posted on 13/5/05 at 05:59 AM |
it really should be steamed out even them I would want to ventilate it properly while cutting.
NS Dev
posted on 13/5/05 at 07:34 AM |
why does it need to be a propane cylinder and what is it for?
I ask cos I have done this many times, but I just go to my local tip and get an old inert gas bottle.
I used "ex-pub" co2 bottles to make a post rammer and a pressure-pot beadblaster, and I have cut up a few balloon gas bottles, which are
similar to the smaller (17kg?) butane or propane tanks, but only had helium in them so are perfectly safe to cut up.
As ever,, the Tip is a very useful source!
Wadders
posted on 13/5/05 at 07:44 AM |
I once saw a full propane cylinder go off, during an out of control fire in a burger van at the Bulldog bash, bloody impressive! it flew like a
missile for about a hundred feet, creating a big pressure wave behind it,hit another burger van and blew that up, causing a huge fire which destroyed
another half a dozen stalls.
Amazingly AFAIK no one was hurt, except a few idiots caught looting in the aftermath.
The band played on throughout the whole episode, with 40 foot flames as a backdrop, very cool.
I'm not suggesting this will happen to you BTW! , although i have had bike petrol tanks
pop when welding, even after being filled with water overnight, so go careful.
NS Dev
posted on 13/5/05 at 07:49 AM |
CRIPES!!!!!!!!!!!!!!!!!
some show!!!
DarrenW
posted on 13/5/05 at 08:07 AM |
I was led to believe that the gas can permeate into the steel over time making it very hard to remove. I recall reading a mag whereby someone
recommended filling it with inert gas first, exhaust gas at a push (as long as the vehicle isnt running rich.
NS DEV - i thought helium was flammable??? Might be wrong. What was that airship filled with (hindenburgh??). I hope its not - my 3 year daughter has
a ballon full of it at home!!!
There must be a safer way to get a pressure vessel - if thats what you want. How do you test them after the mods to make sure they are safe - rather
you than me.
flak monkey
posted on 13/5/05 at 08:22 AM |
Helium is a noble gas, to all intents and purposes, it is totally inert.
Hydrogen on the other hand....
Of all the suggestions so far i would say the submerging in water and then drilling is the best bet. Buy yourself a small titanium coated drill, or if
you are having real trouble get a cobalt one... and go at it with that. Then you should get through ok.
Sera
http://www.motosera.com
posted on 13/5/05 at 08:52 AM |
Some years back a welder was brought in to use a thermic lance to cut through the concrete base of an old dockside crane at what had been the WW2
emmergency port at Cairnryan --- afterr cutting through one to his horror he discovered the aggeragate in concrete contained WW1 mills bomb hand
granades -- while it is almost certain these had been made safe he opted to look for work elsewhere.
What ever happed to thermic lances ? -- one day tomorows technology the next left behind.
What ever happed to jetpacks ? a book idea for uncle Ron and Mr Haynes -- "Build a Jetpack (and race it) for 250 pounds or less
[Edited on 13/5/05 by britishtrident]
posted on 13/5/05 at 08:56 AM |
In the process must have save hundreds from dying of salmonella, BSE and heart disease.
posted on 13/5/05 at 09:35 AM |
The pressure rating on these is not as high as compressed gas cylinders, they are only about 90psi. I used a lorry brake tank to make a compressor way
back when, they are rated higher.
What ever happed to thermic lances ? I used one once to cut a skull out of a furnace when an electrode broke and it shut down on us. They were evil
things with very little control once they were lit. If I remember right it was like a conduit filled with iron filings type material and had oxygen
blown through it. I know it needed a burning torch to light it.
NS Dev
posted on 13/5/05 at 02:18 PM |
Oh, thermic lances are still very much used! I think all the hype that made them all too well known was a couple of big bank jobs that used them
wasn't it??
Certainly still used regularly in demolition and heavy plant dismantling. Murex sell all the bits.
Rorty
posted on 15/5/05 at 05:50 AM |
I don't know about making gas cylinders safe, but when welding petrol tanks, I often did as DarrenW said; just hold the filler neck of the tank
over the end of the exhaust of a running engine for about a minute. This will purge all flamable vapour.
What is the end purpose of the gas cylinder once it's been emptied?
Cheers, Rorty.
posted on 15/5/05 at 10:49 AM |
Problem with degassing petrol tanks is enough petrol can still be lying in the seam weld for air/petrol mixture to get back into the explosive range
---- note explosive not just flamable.
Rorty
posted on 15/5/05 at 01:03 PM |
I agree petrol can be present in seams and deep rust, but the whole idea behind filling the tank with carbon dioxide before welding, is to purge any
oxygen thus eliminating the posibility of combustion.
I would never repair or otherwise weld a tank that had only been washed out as it's not enough to remove petrol fumes.
Cheers, Rorty.
locoboy
posted on 16/5/05 at 06:03 PM |
Thanks for all the replies,
The end purpose is to cut it in half lengthways and weld on a couple of hinges and turn it into a BBQ!
Locoboy
stephen_gusterson
posted on 16/5/05 at 06:46 PM |
10 or 20 quid buys you a barbecue with much less risk of injury!
dont gas cylinders have a deposit on them? take it back and get your money back if so....
atb
steve
stephen_gusterson
posted on 16/5/05 at 06:48 PM |
http://www.krl.com.au/whatisalance.htm
indykid
posted on 16/5/05 at 08:03 PM |
atb
steve
£500 will buy you a nice enough car, that will give a couple of years service at least, with much less risk of injury
at that rate, why even think of building one.
alright, there is an obvious safety risk, but hell, if you were selling them for cost, i'd definitely buy one over a "normal"
barbecue.
barbecueing in a gas bottle, cool
thermic lances, super cool
just my musings, no offence intended
tom
