Poll: How many times did take to pass your SVA?
1) It was easy 23 (230%) ------------------------------------------------------------------------------»
2) I got a list of failures and fixed them all for the retest 24 (240%) ---------------------------------------------------------------------------------»
3) I got a list of failures and still failed a retest 3 (30%) -----------»
4 or more. Look, I passed eventually. 0 (0%) -»
Author: Subject: How many times did take to pass your SVA?
smart51
posted on 21/12/05 at 08:02 AM Reply With Quote
All the best builders pass the second time, right?
zetec
posted on 21/12/05 at 08:15 AM Reply With Quote
A little brown paper bundle of £10 notes under the dash, easy to find when checking the radius seems to do the trick!
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
Hornet
posted on 21/12/05 at 08:16 AM Reply With Quote
Really easy..
bimbleuk
posted on 21/12/05 at 08:32 AM Reply With Quote
Helps if you get the kit supplier to check it over first
Though I still managed to loose a bolt from a rear caliper (trip to a local scrap yard) and took a couple of goes at the hand brake test.
jos
posted on 21/12/05 at 08:51 AM Reply With Quote
Sadistically, I really enjoyed the day of the test.
I had researched the test thoroughly, both here and on the www. I'd also built the car specifically with SVA in mind, concentrating on getting it through the test, and also had the manufacturer, MAC#1, look over it. Even the I still failed on 3 points.
Dash radius
Headlights
Self centering.
All of which shouldve been easy passes but turned out to be fail points. All relatively simple fixes and sorted for the retest (just)
mookaloid
posted on 21/12/05 at 08:54 AM Reply With Quote
Wouldn't say it was easy, but passed 1st time
carlgeldard
posted on 21/12/05 at 09:10 AM Reply With Quote
I don’t know what all the fuss is about. First time pass with a CEC
Carl
posted on 21/12/05 at 09:12 AM Reply With Quote
2 attempts, 1 test, (failed to get to the test at the first attempt) passed after fixing a few things during the second attempt (all fair points raised by the tester).
donut
posted on 21/12/05 at 09:32 AM Reply With Quote
It's all in the preperation. just go round the car looking for edges and loose wiring etc until you are 100% happy then grit your teeth!!
Humbug
posted on 21/12/05 at 10:20 AM Reply With Quote
Snap!
emsfactory
posted on 21/12/05 at 10:40 AM Reply With Quote
3 times butit should have been two due to glasgow's crappy rolling road.
The first fail was fair enough as I didn't really know what I was doing.
posted on 21/12/05 at 11:17 AM Reply With Quote
Just had to adjust brake bias slightly while tester had a cuppa. Do your homework and use a bit of common sense , it's worth it in the end.
DarrenW
posted on 21/12/05 at 01:15 PM Reply With Quote
I would have wordd the question slightly differently - how many appointments did it take to pass SVA???
I wonder how many are answering the question truthfully after failing to get to at least one appointment?
Guinness
posted on 21/12/05 at 02:33 PM Reply With Quote
Two "fail to attends", an actual test and then a re-test.
Mike
jos
posted on 21/12/05 at 03:30 PM Reply With Quote
Okay, alright I did have 1 fail to attend
However, I did get a list of failures and did fix them all for the retest which I passed and was only examined once and retested once.
[Edited on 21/12/05 by jos]
posted on 21/12/05 at 03:34 PM Reply With Quote
And I only had the one appointment.
carnut
posted on 21/12/05 at 07:43 PM Reply With Quote
3 because I knocked out a big end on the way to the 2nd test so couldnt take it.
posted on 21/12/05 at 09:55 PM Reply With Quote
Just the one - Easy
smart51
posted on 22/12/05 at 08:01 AM Reply With Quote
Originally posted by Hellfire
Just the one - Easy
But was that one test the second time you'd put a car through SVA, having written off the first one
posted on 22/12/05 at 04:19 PM Reply With Quote
Category D write-off (Damage repairable)
No requirement for SVA
So thats two cars - just one SVA
bigrich
posted on 22/12/05 at 11:08 PM Reply With Quote
1 test fail (cat emmissions,plug lead supression markings,2 wireing grommets and side lamps not operateing with ignition off ) 2hours work to sort out and 15 mins to retest 1 week later
98rrw fireblade mac#1 type9r
Simon
posted on 23/12/05 at 11:04 PM Reply With Quote
One test, one retest (today - see sep thread)
Simon
OX
posted on 24/12/05 at 11:37 AM Reply With Quote
first car passed first time second car passed on the third go,damn the emissions and noise test
