Author: Subject: r1 emmisions fish tank valves
adrian
posted on 7/2/06 at 09:20 PM Reply With Quote
hi,
im nearly ready to put my car through sva, ive heard people use fish tank valves to reduce the emissions, also i dont have a cat, can u get a cat to fit my silencer as i have no room on manifold (silencer fitted to 4-1 collector)
RazMan
posted on 7/2/06 at 09:24 PM Reply With Quote
Eh? How does that work then?
Raz
adrian
posted on 7/2/06 at 09:34 PM Reply With Quote
hi raz dude!
ive heard that the valves bleed air into the intake thus giving a cleaner burn. the cat keeps gases in the exhast longer burning the bad stuff, im trying to find out where to get these valves? and a cat /silencer in one unit
dave1888
posted on 7/2/06 at 09:40 PM Reply With Quote
IIRC these are bleed valves on the intake manifold which are adjustable. Bogg Bros fit them to there manifolds.
RazMan
posted on 7/2/06 at 09:41 PM Reply With Quote
This sounds much like the Ecotec valve which apparently does similar things. They also claim a significant power increase but I have my doubts.
Anything that ACTUALLY reduces emissions can't be a bad thing but SVA will want to see a cat on an engine that originally had one. I'm borrowing a cat for my SVA then refitting a dummy cat for the rest of the time.
Raz
adrian
posted on 7/2/06 at 09:48 PM Reply With Quote
sorry my ignorance,
what does iirc mean? who are bogg bros?
adrian
posted on 7/2/06 at 09:53 PM Reply With Quote
i AM fitting a cat that was my original question ,i want to know if there is cat that is fitted inside a silencer , i have an r1 does anyone know what fish tank valves to use?
RazMan
posted on 7/2/06 at 09:58 PM Reply With Quote
sorry my ignorance,
IIRC=If I remember correctly Bogg Brothers are well known fabricators /engine builders - if you do a search you will find a lot of results, especially just recently.
http://www.boggbros.co.uk/
I'm afraid I havent a clue about the R1 cat - maybe other R1 builders will step in here.
[Edited on 7-2-06 by RazMan]
Raz
kev R1
posted on 7/2/06 at 10:30 PM Reply With Quote
there was a post on here not so long back from 'snoopy' who used to work for mk i think that goes inyo quite a bit pf detail about this fish tank valve business!
smart51
posted on 8/2/06 at 08:06 AM Reply With Quote
For my carbed R1 I fitted a cat between the down pipes and silencer and then adjusted the idle fuel mixture at my local Hi-Q tyre and exhaust place on their MOT gas analyser to get the readings right.
The guys at Hi-Q were really good as they didn't charge me for using their machine.
I think that some people use valves to bleed air into a slighty rich fuel mixture to get the readings right rather than adjust the mixture but why go to the expense?
Paul G
posted on 8/2/06 at 09:24 AM Reply With Quote
Have a look at this thread:
http://www.locostbuilders.co.uk/viewthread.php?tid=38298&page=2
I used the valves in an emission test last week and it flew through, got my sva on friday so fingers crossed....!
phillippe
posted on 8/2/06 at 06:10 PM Reply With Quote
sva
wot do u think of this ..i took all 4 balance scrows out from between carbs and cilender head and turnd idel up 4 the test and took to my frends mot station ok pass. and took to sva center and passed also.wos i lucky or is it ok.after test i reternd the blanks to wer thay go and turned the idel back down..lol
