<<  1    2  >>
Author: Subject: 2.0 Zetec or V8
jobsagooden
posted on 18/5/07 at 09:27 AM Reply With Quote
2.0 Zetec or V8
Hi all
Now at the final planing stages of my locost which is based on the Haynes Roadster book and need to make an engine choice.
I've got the opportunity for a Brand new 2.0 zetec or a slightly used V8.
I think I'd feel more confident with the zetec installation however the appeal of the V8 is very strong.
What do people reckon regarding the choice and the problems with fitting either.
PJ
flak monkey
posted on 18/5/07 at 09:30 AM Reply With Quote
The bigger question is will the V8 fit in the roadster?
Also depends what you want to use the car for and what sort of driving characteristics you want as well.
Sera
http://www.motosera.com
jobsagooden
posted on 18/5/07 at 09:33 AM Reply With Quote
The car will be a road car and I like the idea of the extra power.
The V8 should fit without too much modification but it might be too much hassle for the extra power gained.
ecosse
posted on 18/5/07 at 09:39 AM Reply With Quote
It probably depends on how much money you have available to spend on each engine, as power wise there may not be much difference between the two.
And as David says how easy will it be to get the V8 into the roadster
Alex
alanr
posted on 18/5/07 at 09:43 AM Reply With Quote
I had a 3.9 V8 powered Robin Hood for 4 years - purely from the driving point of view and the fun the noise the power and the torque -- V8 100%
A
AdamR
posted on 18/5/07 at 09:53 AM Reply With Quote
V8s have been fitted into book locosts, so the 2" wider (IIRC) Haynes Roadster shouldn't cause too much of a problem.
Other than the size difference, I don't think the V8 should be any more complex to install than a Zetec. They are quite simple engines when it comes down to it.
Some say that the V8 torque and weight don't align with the Seven philosophy, but screw that - my philosophy is that I wanted a V8 so that's what I'm building.
vinny1275
posted on 18/5/07 at 09:56 AM Reply With Quote
Scutter is building a Haynes book car with a Rover V8 lump....
V8 noise is always good I think....
jobsagooden
posted on 18/5/07 at 09:59 AM Reply With Quote
cheers guys always looking for that bit mor power and noise!
How about matching the V8 up to the Type 9 box? Will this work or will I have to find a totally different box?
alanr
posted on 18/5/07 at 10:00 AM Reply With Quote
my Hood was mated to a type 9 - had a purpose made bell housing
flak monkey
posted on 18/5/07 at 10:05 AM Reply With Quote
One major thing to remember is cost with the V8
Remember you need 2 exhaust systems, which could be very expensive (best part of £800-1000) unless you can make them yourself of course, then theres no issue.
Why not use the proper box for the job, the T9 wont last all that long if you are a sprited driver, not with the torque from the V8. I think the LT77 box is the one to go for.
Also bear in mind the added cost of fitting something like a 7.5" cossie diff at the back, rather than the std 7" one again to deal with the torque and power.
Just my opinion.
Sera
drlloyd
posted on 18/5/07 at 10:06 AM Reply With Quote
I would check the dimensions of the V8 and work out how/if it will fit. Ive built a chassis that is 4 inches wider than the standard Locost for mine and the V8 only just fits properly. You have to take into account both the vertical and horizontal position as it is obviously desirable to get the engine as low and far back as poss.
Saying that, if it will fit ok I would definitely go for fitting the Rover V8!
DIY Si
posted on 18/5/07 at 10:09 AM Reply With Quote
The 7" diff should be up to the job, i thought they were capable of something like 250lb ft, but not nessecarily for years and years.
Sun Tzu, The Art of War
drlloyd
Oh, and for your info I have fitted mine to an LT77 gearbox from a Rover SD1 Vitesse (Twin Plenum) and also used the rear axle from the Rover SD1. It has not been expensive at all (sofar!).
posted on 18/5/07 at 10:19 AM Reply With Quote
rover v8 is all alloy, zetec is cast iron - the weight difference is not that huge.
rover v8 parts are cheaper than zetec.
how will you fuel v8 - carbs or efi?
smart51
posted on 18/5/07 at 10:21 AM Reply With Quote
a 2.0 zetec with a good EFI system can make as much power as a basic RV8. It will be lighter too. It will be a cheaper install (only 1 exhaust) and will leave plenty of room for the steering column.
Because the zetec's power will be delivered at a higher engine speed, the torque will be spread over a wider rev range, making the car more drivable and the power more tractable. I'd guess that it would use a lot less fuel too.
The lighter weight will improve the handling and the braking.
The V8 makes the V8 noise that some people like. If tuned, it can make more power than the zetec; look at TVRs with the RV8.
jobsagooden
posted on 18/5/07 at 10:31 AM Reply With Quote
for fuel I was thinking Carbs.....
At the moment it seems like 6 of one and half a dozen of the other...
Zetec looks cheaper to start with but the V8 runs close.....
alanr
posted on 18/5/07 at 10:45 AM Reply With Quote
mine used a 4 barrel Holley and with Mallory electrics, lightened and balanced and well set up produced 248bhp at the wheels
posted on 18/5/07 at 11:24 AM Reply With Quote
V8.... go for it.. Chevy 5.7 or an old Ford big block.
No substitute for cubes
jobsagooden
posted on 18/5/07 at 11:31 AM Reply With Quote
what weight does the chevy come in at?
Isn't this taking it just a bit too far?
Sounds great if it'll work though!
flak monkey
posted on 18/5/07 at 11:53 AM Reply With Quote
There's no way, even a small block chevy, will fit in a book or roadster chassis.
You would need at least a +442 chassis, or something a similar size to the dax rush.
What engine YOU choose depends soley on your budget, what YOU want to use the car for, and what driving style YOU prefer. Simple as that. Anything can be done.
[Edited on 18/5/07 by flak monkey]
Sera
jobsagooden
posted on 18/5/07 at 11:57 AM Reply With Quote
Thanks flakmonkey!
Started to spiral out of reality there!
drlloyd
posted on 18/5/07 at 12:07 PM Reply With Quote
The dry weight of a 3.5litre Rover V8 is only 170kgs. I believe (but stand to be corrected?!) that this is lighter than a 2.0 Pinto, I do not know how this compares to a 2.0 Zetec.
razza987
posted on 18/5/07 at 12:14 PM Reply With Quote
Well if you need convincing...
flak monkey
posted on 18/5/07 at 12:16 PM Reply With Quote
A complete pinto engine weighs about 120kg plus another 30ish kg for a type 9 box.
A zetec isnt very much lighter as its still a cast iron block, just has an ally head on. IIRC they weigh in at just over 100kg for a 2 litre. Again plus a gearbox.
Sera
AdamR
posted on 18/5/07 at 01:39 PM Reply With Quote
Not so. The chevy is about the same size as the Rover, just lots heavier. See here.
I'd still go Rover though. More than enough power and torque for me!
<<  1    2  >>
