Author: Subject: diesel engine help please
oadamo
posted on 27/8/07 at 10:04 AM Reply With Quote
hi all my mates got a escort diesel turbo and some times there seems no power as tho the turbo isnt working. and some times it flys. hes had new glow plugs and a oil change. ive checked the turbo and it all seems fine. but ive not got a clue what could be wrong with it. some times on tick over it seems as tho its got a misfire but only a bit.
adam
ned
posted on 27/8/07 at 10:45 AM Reply With Quote
does it have an intercooler? have you checked all the boost pipes?
beware, I've got yellow skin
posted on 27/8/07 at 11:20 AM Reply With Quote
what age is it? My sprinter goes into safe mode at times due to loss of boost, similar to how you describe.
oadamo
posted on 27/8/07 at 11:29 AM Reply With Quote
its a m reg escort estate. i think its 1995
he sent it to the garage but they couldnt find what was wrong so they just give it him back lol. and charged him 220 for plugs and oil
adam
iceman26
posted on 27/8/07 at 11:55 AM Reply With Quote
how many mile has it done as the inlet
manifolds get bocked up with crap
and need to be removed and cleaned
oadamo
posted on 27/8/07 at 12:00 PM Reply With Quote
145000 ish so its done alot but it does run ok. just feels down on power but then sometimes you put your foot down its like a rocket. well sort of lol.
adam
iceman26
posted on 27/8/07 at 12:16 PM Reply With Quote
i take it you have changed the fuel filter.
have had probems at work with some cars
that need them changed after 3500 miles
oadamo
posted on 27/8/07 at 12:52 PM Reply With Quote
i dont think hes had the filter changed ill have to ask him.
adam
posted on 27/8/07 at 03:20 PM Reply With Quote
Is it a variable vane turbo? Sometimes the vane actuator arm can jam intermitently..... Would be interesting to temporarily attach a boost gauge and see what is happening....
repper
posted on 27/8/07 at 04:27 PM Reply With Quote
hi mate
iv have had a car's at work with simla probs try the advance solanod in the injector pump you can get the from after market factors like andrew pagers idd get some one ho nose what thay are doing to check it as thay are not cheep and you have to strip down part off the pumps lume as it shear the wiring plug
hope it helps
repper
posted on 27/8/07 at 04:38 PM Reply With Quote
doh posted it twice
[Edited on 27/8/07 by repper]
posted on 28/8/07 at 08:15 AM Reply With Quote
Defniately something wrong then, the 1.8TD engine emits more power in sound energy than it sends through the crankshaft!
I would check for a sticking wastegate actuator, and for a sticking/faulty EGR valve (quite common as they get caked up with crud). You will probably find the entire induction system 'upwind' of the EGR valve is filled with something resembling black dairylea cheese due to the exhaust gasses, a lot of people bypass them.
richijenkin
posted on 28/8/07 at 11:03 AM Reply With Quote
Ive seen this problem with a golf, not sure if it the same on an escort but it was the MAF sensor. The tube like device going into the air filter. Unplug the wires going to it and see if it feels like your symptoms?
Rig
