welderman
posted on 23/6/08 at 02:13 PM |
R1 Expansion tank
Hello.
Going to make up an ally expansion tank approx 1ltr capacity, what size pipes do i need to come out of it.
25mm from bottom ?
10mm from top?
Not quite sure.
Oh 2003 R1 inj.
Thank's, Joe
I don't stalk people
welderman
posted on 23/6/08 at 02:15 PM |
like this but not polished
![](/galpreviews/a764741-1640_2.jpg) ![Rescued attachment 1640_2.jpg](/gallery/a764741-1640_2.jpg) Rescued attachment 1640_2.jpg
Thank's, Joe
worX
posted on 23/6/08 at 02:18 PM |
12mm in and 8mm out...
nib1980
posted on 23/6/08 at 02:19 PM |
I bought one of these a lot easier and fatastic qauilty when it turned up
LINKY
[Edited on 23/6/08 by nib1980]
welderman
posted on 23/6/08 at 02:21 PM |
linky not working
Thank's, Joe
nib1980
posted on 23/6/08 at 02:22 PM |
quote: Originally posted by welderman
linky not working
try it now
Jubal
posted on 23/6/08 at 02:34 PM |
You will have the same minor headache making it all connect up as I did.
The bottom of the expansion tank ideally wants to tee into the bottom hose. You could make a reducing T/elbow like you did for mine and use any size
outlet on the tank you like. The top of the tank wants to be 8mm ID, assuming you intend to gather the various small hoses together (top of
thermostat, couple from the block and the small outlet from the top of the rad) and have them terminate there. They are all 8mm ID hose.
I am by no means expert on any of this (or anything). I just followed the advice I was given at the time and it's working great. Regurgitating
it here in case it helps ![](/images//smilies/bigsmile.gif)
welderman
posted on 23/6/08 at 03:04 PM |
Ta, is this the one to go off.Image deleted by owner
Thank's, Joe
welderman
posted on 23/6/08 at 03:06 PM |
any pictures Derek
Thank's, Joe
Jubal
posted on 23/6/08 at 03:48 PM |
That's the job. I found there was another 8mm hose coming off the block which I tee'd into the top of the expansion bottle.
welderman
posted on 23/6/08 at 05:16 PM |
being lazy now, if ive got some 100mm dia tube and want a tank approx 1ltr, what would be the cutting length.
I think that 150mm long would give me about 1.2 lts of water, is this about right?.
Thank's, Joe
adithorp
posted on 23/6/08 at 06:02 PM |
Somebody should have paid more attention at school.
adrian
welderman
posted on 23/6/08 at 06:04 PM |
i did just making sure before i cut the tube .
How was Newark
Thank's, Joe
adithorp
posted on 23/6/08 at 06:38 PM |
Windy!
adrian
welderman
posted on 23/6/08 at 06:41 PM |
did car run smothly though, and dont have a curry before you drive,
Thank's, Joe
paulmw
posted on 23/6/08 at 06:48 PM |
Do the Hoaky Coaky an turn around......
adithorp
posted on 23/6/08 at 09:13 PM |
Car ran well both ways. Doesn't like "slow" though. Bit on the weak side but I'll soon sort that. I'll try and get round
to see you this week.
adrian
ChrisGamlin
posted on 23/6/08 at 09:14 PM |
Yep, when I drew that diagram I forgot that I'd ditched the T piece that feeds into the throttle body choke / cold start valve and also into the
header tank or top of the rad on the bike (not sure which off the top of my head).
Mine is just plumbed so the 8mm bleed from the water pipe outlet goes directly into the choke, then the outlet from that goes straight into the block.
It might make bleeding a little trickier in theory but Ive never had any problems, and saves having another T and another inlet into the expansion
tank.
Chris
[Edited on 23/6/08 by ChrisGamlin]
welderman
posted on 23/6/08 at 09:22 PM |
Chris hope you dont mind using your picture, but it pops up everywhere, .
Joe
Thank's, Joe
ChrisGamlin
posted on 23/6/08 at 09:38 PM |
No probs, maybe I should have put a copyright on the bottom and claimed royalties
welderman
posted on 24/6/08 at 08:07 AM |
class
Thank's, Joe
