Author: Subject: Best way to remove powder coat?
mr henderson
posted on 20/8/08 at 07:22 PM Reply With Quote
I need to reweld an item that has been powder coated. Unfortunately it will be at least partly visible, so a neat appearance after the work is done would be good.
Any suggestions? Especially any that don't involve heavy expenditure of cash or time?
John
stevebubs
posted on 20/8/08 at 07:27 PM Reply With Quote
Plasticote paint looks very similar to powdercoat...
stevebubs
posted on 20/8/08 at 07:28 PM Reply With Quote
Second question - how big is the item in question? If it's only small you may find a local powdercoater who will slip it in with a bigger batch for a nominal charge...
posted on 20/8/08 at 07:31 PM Reply With Quote
We recently removed the powder coat on lower rear wishbones using a flap disc in the angry grinder. Worked a treat.
Phil
Dave J
posted on 20/8/08 at 07:46 PM Reply With Quote
Flap abrasive disc to remove powdercoat, then fine wet and dry to feather down the remaining powdercoat edges. Recoat using a black enamel paint. Spray or brush, either goes on to a very smooth finish (probably a better finish than the exisiting powdercoat!)
Dave
Phil.J
posted on 20/8/08 at 09:10 PM Reply With Quote
Nitromors paint stripper will disolve powder coating.
posted on 20/8/08 at 09:11 PM Reply With Quote
I used a wire brush in my angry grinder - not many coatings can withstand that sort of attack!
posted on 20/8/08 at 09:38 PM Reply With Quote
Powder coat is relatively removable with an angle grinder. A flap disc would leave a smooth finish but for welding I'd just use a grinding disc.
I'd second a vote for Plasticote satin black. Looks just like the Powder coat on my STM chassis and roll bar (though I can confirm that it's not!!!!)....
Maradona
posted on 21/8/08 at 04:39 AM Reply With Quote
for me flap abrasive disc, and to paint, maybe epoxy paint from PPG will be nice
[Edited on 21/8/08 by Maradona]
Diego,
The locost builder from Argentina
posted on 21/8/08 at 06:06 PM Reply With Quote
Paint stripper followed by wire brush in angry grinder
Jason Fletcher
posted on 23/8/08 at 07:50 PM Reply With Quote
a blow lamp to soften it up followed by a wire brush will take it off.
If its a small item then I could powdercoat it for you for the cost of postage or you could used Hamerite's satin black which an exact match to the normal satin black powdercoat.
Jason
