Had a lumpy idle on the R1 which has gotten worse since having the engine, especially noticable since the Power Commander and rolling road was
completed 2 weeks ago.
Had a look at the map today and just cant get a smooth tickover.
Took a plug out and a quick call to Andy @ AB with plug part numbers - the engine has NGK Iridium plugs, that should'nt be in the engine as they
are race plugs and need regular changing. They have been in the engine since buying it - so 2.5yrs old and could account for the deteriorating
tickover.
Thanks to Andy who's sorting a "proper" set of plugs.
Gutted another weekend not using the car
We had some of those NGK Iridium plugs go on us at Snetterton on a test day, they seem to be quite troublesome, Glad you got it sorted though!
I've just renewed a set of NGK Iridium plugs after 10000miles trouble free use.
NGK Iridium should be good for the life of the engine even without re-gapping.
Sounds like the plugs were the wrong heat range for the engine or mixture is out.
Nope, Andy checked..... they are definetly the wrong plugs
This explains it NGK technical info
New plugs ordered from Andy & will be fitted this week.
If the lumpy/inconsistant idle doesnt sort itself out, im getting rid
