Blade turbo
welderman - 24/2/07 at 01:03 PM
Am i right in attatching the air vents and breather pipe to my plenum chamber via the small tube in the plenum pipe.?.
welderman - 24/2/07 at 01:05 PM
Your thoughts welcome please.
dilley - 24/2/07 at 01:30 PM
the middle one on mine runs straight to the plenum, the left and right run to the inlet pipe of the plenum, one on either side, there are pictures in my archive.
dilley - 24/2/07 at 01:40 PM
How have you attached the plenum to the carbs? did you remove the plastic tops and bolt directly on to the carbs? have you got a picture?
Andrew.
welderman - 24/2/07 at 02:45 PM
fitted to tops as you say, will chack out you pic's ta.
Joe
welderman - 24/2/07 at 02:47 PM
top
dilley - 24/2/07 at 02:51 PM
Ive been having trouble getting mine to seal, im running short rubber joiners but there isn't a lot of room on the plastic.
I thought about doing the same as you, but there seems to be a recessed area on the bottom of the plastic part and I didn't know how it would affect the jets under the trumpets if I put a plate directly on top, mine is on a blackbird but I think its the same setup.
[Edited on 24/2/07 by dilley]
dilley - 24/2/07 at 02:56 PM
looking good! youll soon run out of space though especially if you fit an intercooler and pipe work
welderman - 24/2/07 at 03:06 PM
just dropped it in to see if it fitted.
IT FITTED
welderman - 24/2/07 at 03:07 PM
not giong to run intercooler yet, going to see how it goes, yours looks good though mate.
dilley - 24/2/07 at 03:09 PM
did you leave the trumpets ?
welderman - 24/2/07 at 03:10 PM
welderman - 24/2/07 at 03:11 PM
no left the trumpets off
dilley - 24/2/07 at 03:22 PM
As you look at the plenum inlet the left and right 10mm pipes go to the left and right feeds on the carbs, the middle one inbetween the 4 carb outlets goes directly to the middle pipe that is inbetwwen the carbs, if that makes sense, that should cover the 3 you needed to know.
dilley - 24/2/07 at 03:23 PM
I missed one, the bottom right one in the picture goes to the fuel pressure regulator.
welderman - 24/2/07 at 03:36 PM
so if i take the four carb air feeds to one of my 10mm pipes and the other end to to my carb breather, then all i need to to is a new outlet to my fuel pressure reg. Or do i need to do that.?.
garage19 - 24/2/07 at 05:40 PM
You should probably use one. Did you know that tthe charge temp will be about 120-150 C when it leaves the turbo!
Are you using a mallapassi fuel presure reg?
welderman - 24/2/07 at 05:46 PM
120-150 C when it leaves the turbo!. No
Useing a regulator from a metro turbo.
garage19 - 24/2/07 at 05:59 PM
Yup, that hot!
The metro one is a malapassi item.
Same as used on the early carbed lotus espirit turbo.
welderman - 24/2/07 at 06:21 PM
Yup, that hot!
Nice one with the regulator then.
So maybe a intercooler then?
But some people dont use them.
dilley - 24/2/07 at 06:33 PM
yes you will need a feed from plenum to regulator.
the_fbi - 24/2/07 at 06:47 PM
Intercooler will always be worth it. It'll lower charge temps and allow higher boost pressures.
At the very least it'll lower charge temps and reduce chances of any detonation.
Shouldn't cost much more than £100 for a nice one, including any hoses/clamps you need. Definately worth every penny.
[Edited on 24/2/07 by the_fbi]
mb893 - 24/2/07 at 07:14 PM
How much boost are you running?
My car running 7 - 9psi has an 'uncooled' charge temp of less than 40deg on 18 ambient.
Couldn't sensibly fit an intercooler so went for WI... With that running, the charge temp drops to around 25 deg on 18 ambient with 100% screen wash.
All temps measured with a thermocouple in the airbox inlet.
welderman - 24/2/07 at 07:55 PM
will look out for an intercooler may be on ebay.
so i need to put another feed for the regulator.
are any of you using a air fuel ratio meter with a lamba sensor fitted.
and i dont know what the boost will be yet, engine needs a selector fork still so may even get some turbo pistons.
garage19 - 25/2/07 at 09:39 AM
You don't need turbo pistons, just two genuine honda head gaskets.
That is what haleshot used to use until they sourced a custom thicker one from the states. They ma sell you one of these if you ask.
welderman - 25/2/07 at 10:27 AM
i found holeshot a bit, errr, not very forth coming for info, but hey there in buisness to sell things. But im ok on that.
Will only go the MAD route if the gear box is goosed, but for now 2 gaskets will do me fine.
So how much boost you got garage19 ?.
JoelP - 25/2/07 at 10:49 AM
downside of the intercooler is increased lag as there is a greater volume to pressurise. You want to work out if you really need it or not, obviously at very low boost its totally unneeded, at high boost its very much needed. All IMHO
mb893 - 25/2/07 at 11:27 AM
AT 0.5 - 0.8 Bar you really don't need an intercooler... Apart from you can't fit a big enough in a sevenesque to make that much difference at that level. Hence my temp post... No where near 100 deg+ going into the engine!
I've found WI a simple and effective way to the job - well a lot more than the job actually.
You'll need to fit a 1.7mm COMETIC head, gasket rather than two standard ones, to drop the comp a tad. Unless you're going for 1.1 Bar+ low comp pistons are... expensive and not needed.
You also have to concider the clutch. The turbo puts a lot more torque through it and simply bunging in the 'Uprated' or 'Heavy duty' junk that's available really won't do the trick. Think less than 100 miles between clutch changes.
At the levels I'm running there are fixes out there that work, but if you intend on running more than 0.5 - 0.8 Bar you will need to redesign the whole clutch system...
Edit for:
My car did run with a 1ltr intercooler - with no lag. Took it out beacause of cooling issues... So with bike engines, unless you're running a huge turbo that's not matched to the engine I don't think lag is much of an issue.
Rather the other way around in that the power on a N/A engine comes in a what - 5-6Krpm... with my system the power really starts at around the 4K mark.
[Edited on 25/2/07 by mb893]
welderman - 25/2/07 at 01:43 PM
so then, we cant decide on an intercooler.
Ive just bought a facet red top pump.
need to weld on another pipe for the regulator.
cometic for a new thicker gasket.
owt else?.
dilley - 25/2/07 at 02:17 PM
i have a lamba sensor position on my exhaust for setting up purposes.
garage19 - 25/2/07 at 04:49 PM
Along while ago i used to think that too until i did the calcs for a huge RS500 style car intercooler. If you read the compressor map and work out how much volume of air your compressor is shifting at certain points and then calculate the volume of your IC, you will see that even on a big RS500 cooler it actually only takes a tenth of a second to fill.
So go for the biggest IC you can fit.
garage19 - 25/2/07 at 04:50 PM
Before i sold the bike she was running nearly 10 psi.
welderman - 25/2/07 at 10:16 PM
What kind did you go for a digital one or the led dot one?.
the_fbi - 25/2/07 at 10:44 PM
Given the way the £/$ is currently, great time to invest in a Wideband Lambda.
circa £101 delivered.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=150088462859
Just waiting for mine to arrive......
welderman - 26/2/07 at 08:47 AM
[/quoteDont see a guage for itm though.
the_fbi - 26/2/07 at 09:42 AM
Plug it into your PC and you get it all on the screen. Perfect for initial setting up and health checks.
Can run it into a DVM too if you want a standalone display rather than a laptop.
welderman - 26/2/07 at 03:46 PM
think this will do for the intercooler?.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=160087819517&ssPageName=STRK:MEWA:IT&ih=006
the_fbi - 26/2/07 at 06:24 PM
Personally something like
http://cgi1.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=130081926213 (although width could be an issue)
or
http://cgi1.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=180087564284
Which are nice and small
Really shouldn't need to be over £30 for a small intercooler. Just try and get one without plastic end caps as these generally blow off at high boost levels (not that you'll be near them).
welderman - 26/2/07 at 07:41 PM
just found this baby
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=220002956948&ssPageName=STRK:MEWA:IT&ih=012
dilley - 26/2/07 at 07:53 PM
Where are you thinking of mounting it?
welderman - 26/2/07 at 07:55 PM
not sure, i can fab up almost anything so who knows, passenger seat, cause no one will probably get in after ive fitted the turbo.
dilley - 26/2/07 at 08:10 PM
they will...only once though
I origionaly mounted min in the nose cone but had cooling trouble, I have now moved it under the bonnet in front of the scuttleDrivers side and mounted a scoop aboveit, so far so good.
welderman - 26/2/07 at 08:14 PM
ye, seen it in your archive it looks very tidy under there. But that plenum looked a bit untidy with all that stuff on it.
dilley - 26/2/07 at 08:18 PM
I covered it in araldite as a quick fixIt was all down to Holeshot, but that a different story...... Its now been sorted thanks to pathfinder, and is now polished.
welderman - 26/2/07 at 08:39 PM
dilley, do you think this will do the trick?.
dilley - 27/2/07 at 07:29 AM
get some dimensions,personally I would go for something not so thick and larger-more surface area.
welderman - 27/2/07 at 07:45 AM
get your driftmate, will check ut the old ebay today.
Joe
welderman - 28/2/07 at 06:42 PM
Hi fellas, do you all run boost guages?.
the_fbi - 28/2/07 at 07:22 PM
Yip, essential so you know whats going on!
welderman - 28/2/07 at 08:02 PM
any paticular make or are they the same.
the_fbi - 28/2/07 at 08:11 PM
I wouldn't cut a corner on a gauge. Autometer (not Autogauge) are good quality and cheap from USA via eBay.
You may struggle to find one which gives you a 9-10 psi max, or even 1 bar, and you don't really want a 2+bar unit as you'll never use more than 1/3rd of it.
Autometer do a 20psi unit as their lowest afaik.
Shouldn't be more than £8.00 posted from the US and the gauge will only be £23 on the current exchange rate. Similar gauge in the UK will be an easy £45 + delivery.
May be some cheaper 2nd hand on eBay or other forums.
dilley - 1/3/07 at 01:28 PM
I have an oil filled gauge that I got from holeshot, its suppose to be megga, I only changed it because Im running turbosmart e-boost which has a digital read out. I also have a another gauge both are as new condition.
[Edited on 1/3/07 by dilley]
welderman - 1/3/07 at 02:15 PM
Does that mean you may have one for sale Mr dilley.
welderman - 1/3/07 at 02:22 PM
also do i need to get the exhaust gasses out asap, ie if i have two exits one 50mm and the wastegate is 25.
I can weild a 75mm tube over the 50mm and 32mm over the 25mm hole so it escapes quiker or do i just stick with a 50mm one and 25mm one.
These exit pipes will be joined after about 60 mm. Rescued attachment d9_1.jpg
dilley - 1/3/07 at 07:59 PM
Yes I have got 2 gauges for sale,
Do you have an exhaust flange for the
turbo??
welderman - 1/3/07 at 10:11 PM
dilley, might be interested in a guage, and yes just this second finnished the flange.,
dilley - 2/3/07 at 07:46 AM
what did you dicide to do on the exhaust, I wasnt too sure when you asked
welderman - 2/3/07 at 12:11 PM
[Edited on 2/3/07 by welderman] Rescued attachment exhaust3.jpg
frankycopp - 5/3/07 at 03:50 PM
is there anyone that would make a turbo kit for me?
quadra - 5/3/07 at 06:42 PM
I have a 2wd sierra cosworth intercooler that used to be on my Dax Rush, it fits inside the nosecone above the radiator. Are you interested, its in good condition. I have upgraded to a larger intercooler as I am running 25psi now.
Mike
dilley - 5/3/07 at 09:54 PM
25psiall the time?
Simon - 5/3/07 at 11:07 PM
Renault 5GT T intercoolers, with plastic bits removed, and ally welded on instead. Also changed the flow from in and out at same end to straight through.
I/c's were about a fiver each
simon
quadra - 6/3/07 at 12:32 PM
Boost peaks at 25psi and then holds about 22psi, certainly shifts.
Mike
mb893 - 7/3/07 at 05:25 PM
Welderman,
U2U sent... Sorry for the delay, only just noticed I had a message :-)
[Edited on 7/3/07 by mb893]
welderman - 11/3/07 at 09:02 PM
mb893, thanks mate not been on for a few days myself. Ta for the info.
Joe
welderman - 11/3/07 at 09:03 PM
simon
Bloody hell wicked man.
G.Man - 11/3/07 at 09:15 PM
simon
Looks a nice construction, as a subaru owner tho, can I say heatsoak?
Make sure you have good scoops
Simon - 11/3/07 at 10:59 PM
No worries about heat soak. Air in at top, through i/c's then vented out of sides (these are ducted under coolers). Note side panels are proud for air extraction with forward facing vents for air entry (primarily for air to filters). There's a vent on top of bonnet behind rad, and nose section slightly wider to allow for air extraction
Maybe a bit of overkill
Simon
[Edited on 11/3/07 by Simon]
welderman - 12/3/07 at 08:41 PM
blimey theres alot of filler in that, hope i dont have cooling problems cause if i do might run it without the bonnet on,
dilley - 12/3/07 at 08:58 PM
Im still having some issues with mine, I think I may have sorted it now,just...££££new rad
welderman - 12/3/07 at 09:38 PM
so did your set up from holeshot not come with a diferent rad.
Oh and your on for the trip just need to find time, but over 3 weeks is better for me, ta for that too.
Simon - 12/3/07 at 11:49 PM
Err, the bonnet has been turned into the buck. It'll be moulded, then I'll make a new bonnet.
But you knew that, didn't you
Simon
dilley - 12/3/07 at 11:53 PM
No I didnt gt a rad from holeshot, cooling both oil and water is something that needs looking into on all turbo becs, next stage for me is to find out what my intake temp is.
welderman - 14/3/07 at 06:53 PM
Simon
did you not fancy cutting some hose with some gauze over them
welderman - 19/3/07 at 10:57 AM
Can you peeps running turbos complete the arrows please, going to add another outlet to my plenum chamber tonight so this is the next step forward.
dilley - 19/3/07 at 04:13 PM
Left: fuel in
Bottom: fuel return to tank
Top right: feed from plenum
Bottom right: fuel out to carbs
welderman - 19/3/07 at 04:21 PM
Nice one dilley, your a gent.
dilley - 19/3/07 at 04:24 PM
No probs! just make sure its ready for York
welderman - 19/3/07 at 06:54 PM
thats if its blooooming ready, eat, live, sleep, work at the min.
welderman - 18/6/07 at 03:05 PM
worX picture, if you want more just ask.
welderman - 18/6/07 at 03:10 PM
welderman - 8/8/07 at 06:22 AM
Finnally collected the car from, Malc at MB and im very happy with the results, i cant put a figure on what Malc has done on the turbo side as his bill came with the added parts i needed for the clutch and gear box etc which had been abused , just need to fit some bits of body work i removed prior to Malc doing his work. Will keep posting as i get some use out of it. Rescued attachment turbo engine in again.jpg
zxrlocost - 8/8/07 at 08:07 AM
so what kind of performance results are you hoping to get?
welderman - 8/8/07 at 09:01 AM
looking at approx 180 at the wheels, took it for a spin round the block, phenominal.
Thats a big work for me
welderman - 21/11/07 at 04:03 PM
not been updated for a while.
Firstly the car is running lean at the mo so that needs sorting out, but since i started the build, ive also got some new Hi-spec brakes, some team dymamic 15" wheels and R888's.
Not to mention a daAvies craigggg booster water pump. Plus some other sundry bits too.
Kriss - 21/11/07 at 04:27 PM
very intresting build. Best of luck with it all.
Are bike lumps converted to turbo common, esp on the 'Blade?
welderman - 2/12/07 at 11:41 AM
richard thomas - 2/12/07 at 03:31 PM
I love that manifold...gonna have to do something similar due to clearance issues. Question though, have you noticed any lag due to the length of the primaries to the turbo?
welderman - 2/12/07 at 05:16 PM
not noticed any lag at all, i might do when i fit the charge cooler, but im told that as the engine is in a higher rev range under boost that it will be very minimal.
richard thomas - 2/12/07 at 05:20 PM
That'll do for me
welderman - 2/12/07 at 10:56 PM
made your mind up then, did'nt take much!
