Just been having a chat with some people on the mini forum. Ive directed them here for more info. Just thought id check what i was saying is correct
(im 99% certain it is).
You have a mini. Its rotten. 2 nice ioptions are new steel shell or one of those FRA mini shells (fibreglass). Opting for GRP is a radical chassis mod
and IVA is required.
There was also an article in this months mini mags covering that VOSA might be getting stricter on other cars needing IVA (eg limo's, mini
sorties etc).
Wasnt there something about a company making GRP shells for VX Nova's a couple of years back? Didnt they have to go on a Q plate? Do you reckon
DVLA would do the same for GRP mini shells? Or could they be classified as a kit car, get a cert of newness and be registered on a current plate?
if you're reshelling a car, ie taking the bits out a rotten shell, and putting the bits in a new one, identical to the original, then it
won't need IVA.
fibreglass minis would be classed as kit cars i reckon. the same as taking a sierra, and re-shelling it into, er, a 7
tbh I thought full GRP monocoque bodyshells needed type approval (i.e. crash tested) to be used on the road
You are correct Darren, a GRP chassis isn't OEM spec therefore IVA required.
Mr Whippy - incorrect no type approval is required, but if it's a new, unproven, design the IVA man will need to be satisfied it's strong
enough. Lots of GRP monocoque mini kits over the years (GTM rossa and the new ones, the Dominos, Mini Marcos/Gem/Kingfisher, Midas Gold/Bronze etc
etc etc).
Mr Whippy - incorrect no type approval is required, but if it's a new, unproven, design the IVA man will need to be satisfied it's strong enough. Lots of GRP monocoque mini kits over the years (GTM rossa and the new ones, the Dominos, Mini Marcos/Gem/Kingfisher, Midas Gold/Bronze etc etc etc).
grp mini shells - where from and how much?
There was a mini made with a fiberglass shell wasnt there? It was slighly lower than a normal one too.
Mini minus seems to ring a bell but not sure.
How do you satisfy the IVA man then? tbh as far as I'm aware they did have to crash test those kit cars (not something you'd volunteer to do as its so expensive) -
Meant to say in my post, a re shelled car would need to be the same as the original (ie welded steel) not just look the same. Same as the whole issue
with 'duttons' being re-chassied with a mnr or stuart taylor chassis that we see on ebay a lot
The mini minus was a grp mini kit. Mini pimlico was another i think. I'm sure there was another that started with a D. I'll check later
Hi Blake, the 'D' would be the Domino, same company as the Pimlico ISTR. The GTMs were crash tested because they wanted to sell turnkey cars, there was no other reason to spend loads of money to have it done.
yes ^ domino thats the one
GTM never crash tested the Libra or Spyder (or Rossa as far as I can remember).
I put a grp mini minus through sva earlier this year and had no issues regarding the strength of the body. Might be because it had a full rollcage in
it to hold the gsxr1000 engine in the back. Even got it on an '09' plate thanks to Northampton dvla.
The full build is on the mini forum but if it wasn't for the info on this site I would have really struggled to finish it. Unfortunately it seems
that most of the mini community feel that iva's are something that doesn't affect them no matter what they do to their car.
