Will small exhaust leak effect emmissions?
-matt - 22/11/11 at 07:52 PM
Been filling in some pin holes in the welds in my manifold that i made.
Just wondering, if i miss a couple, will this effect the emissions much?
There is no lamda sensor to corrupt. And manifold will be heat wrapped if that makes any difference.
So would a tiny leak cause me to fail the emmissions test? or do i need to make sure i fill them all?
Im not too worried about the exhaust long term, as planning to get something custom made after IVA.
Paul (Notts) - 22/11/11 at 08:00 PM
What engine and what level of emmissions test will it have to pass?
-matt - 22/11/11 at 08:27 PM
Its a 2008 R1. Not sure what the emissons level are?
MakeEverything - 22/11/11 at 08:28 PM
Shouldn't make a difference.
britishtrident - 22/11/11 at 08:38 PM
Exhaust assembly paste ( FireGum or similar) will seal it until it carbons up.
-matt - 22/11/11 at 08:47 PM
Thats what ive been using (the ceramic type that comes in a tube for a gun).
I also need to use some around the flange that goes into the head, as thats leaking slightly.
Just wondering for if i miss any leaks.
ReMan - 22/11/11 at 09:43 PM
I'm not convinced they "carbon up " any more since the good bits wrer taken out of petrol?
r1_pete - 22/11/11 at 09:48 PM
Persevere and weld them all up, nothing else is permanent.
rusty nuts - 23/11/11 at 06:35 PM
Even a small exhaust leak on a car with cat and Lambda sensor can cause the Lambda reading to be too high for MOT purposes
-matt - 24/11/11 at 12:27 AM
Even if there is no lambda/02 sensor?
rusty nuts - 24/11/11 at 09:34 PM
That may depend on what your emmision limits are ? If you have an age related plate you may have a lower limit than a Q plate
bertie_bas205 - 24/11/11 at 10:18 PM
It wont effect the emmisions but surely the system has to be "gas tight" to save nasties getting into the car......?
Bertie.
