Currently building an Indy using Sierra donor diff, gearbox + steering rack, most other parts are brand new (with receipts). I have the VIN plate and
registration document from the Sierra, from memory I think its a 'K' plate.
I didnt purchase the original kit, I have the original receipt from MK but it isn't made out to me, its in the name of the person I bought the
kit from.
Im using a brand new crate blacktop Zetec, which was purchased from GBSC. I have a receipt for the engine but dont have any documentation and the
engine is not stamped with an engine number.
Firstly, am I using enough from the donor to register the MK on the original 'K' reg plate and will I have any problems due to purchase
receipt for the original supplied kit is not in my name?
Secondly, where do I stand with emissions? Do I need to fit an exhaust with a cat?
Cheers Nick
the engine is not stamped with an engine number.
Rather strange.
Ford service engines dont have a number, dealers stamp the number off the motor coming out.
Not unusual to not have a engine number, i stamped one on mine using ford coding.... And you will need a CAT for emissions im afraid.
unless you stamped the engine number from an old cvh or pinto then got a letter from ford, I wouldn't try it though just incase the inspector knows the difference between a brand new zetec and 20 year old CVH!
The engine number i made up using ford coding was to show that the engine was a 2005 engine....
Cheers for the quick replies.
Will it be relatively straight forward to register it on the donor reg even though I am not using the donor engine?
Mikeb, dont think Id get away with stamping it with the original Sierra number, worth thinking about but I reckon even my missus could spot the
difference
It dosent matter who's name is on the original receipt, but it will help if you have a receipt from him also stating what work if any had been
done.
ps keep taking the build photos.
[Edited on 30/11/11 by jrrsparky]
