Hi
I currently have racveleda uprights with raceleda 4 pots, but there is a 2mm pad over hang on a 247mm diameter cortina solid disc.
I have run it like this for 3 years no big deal, but am now looking to upgrade to hi spec either lug mounted or ideally radial mounted with 280mm
discs.
Does any body know where to buy different brackets that bolt on the raceleda uprights?
Can you get a 252mm diameter solid (none vented 9mm thick) cortina disc?
Advice links would be much
Thanks Gareth
Try calling Chris @ mnr racing they bought raceleda out when they went bust !!!
Originally posted by GBaggott
Hi
I have run it like this for 3 years no big deal, but am now looking to upgrade to hi spec either lug mounted or ideally radial mounted with 280mm discs.
Thanks Gareth
