919 blade clocks
Paul (Notts) - 26/3/12 at 08:15 PM
919 blade clocks.
After a set of clocks for a 919 blade engine. Don’t know much about motor bike engines and there seem to be a few variations. So any advice welcome.
Paul
mark chandler - 26/3/12 at 08:35 PM
Make sure you get the bit of harness to go with them !
I got some 919 all in one clocks, pig to attach wires to the little pins but they work well.
9 boltheads on the prop gets you very close to correct speed on the mph clock with 3.65 diff and 185/60/13 tyres, this was just using a scrap ABS sensor from the sierra.
I cut a hole to recess the clocks in my panel, I could/should have split them (they screw together) then cut a hole smaller and sandwiched the ali dash panel.
Regards Mark
