Hello all,
I'm on the last fumes of a argon/co2 5% mix bottle, what is the latest best deal out there at the moment looking for a medium size bottle about
10 litres.
I'm based in Chandlers Ford, near Southampton SO53 2FF
BOC do a decent deal on Argoshield, it's what I intend to use;
http://www.boconline.co.uk/products/products_by_type/industrial_gases/shielding_gases/argoshield/2_litre_argoshield_light_filled_cylinder.asp
£18 annual rental, £16 to fill. Although I've just noticed you'd want five of them....
try
www.adamsgas.co.uk
I use "Moon" gas. Well actually it's "Half Moon" gas.
Two pints of best bitter, pkt of salt & vinegar, cylinder of CO2 ..... £21.80
Bargain.
Paul G
Been lookng myself found a hobbyweld stockist cost is as below
Hobbyweld Cylinders are RENT FREE
Pay a one-off deposit of £50.00 + VAT
Refundable upon return less a £15.00 administration fee
Pay only for gas, no collection or hidden charges
Cost of Hobbyweld 15 is £30.00 + VAT
Equivalent amount of gas to 23 x 600ml disposable cylinders
9.5 Litres of gas per cylinder
Standard industrial cylinder connections of 5/8 BSP Female RH, compatible with all other UK industrial cylinders
Cylinder Gas pressure 137 bar at 15C
Dimensions - Height 940mm, Diameter 140mm
Weight 17Kgs
How does that compare?
Check out "MigTigArc" in Portsmouth, one off charge for three years hire, and then so much a fill up. Its who I use and find them very useful for all my welding bits and peices. HTH Ray
http://www.mig-welding.co.uk/forum/showthread.php?t=14605&page=34
Thanks everyone I will look into each offer and see what suits me best
Weight 17Kgs
