hi i have a d-link nas drive i have got hd films on it and when streaming to my media player
it freezes all the time .
has anyone had this and can the fault be fixed
thanks
What media player are you streaming it to? Can it cope with HD quality films? It could be possible it is the media player? And in what format are the HD films? I stream HD films using a dinosaur NAS drive (as in old, not the brand!).
How have you connected the NAS to the media player?
hi im running a XTREAMER Full HD Sidewinder 3 it works fine if i just plug a hard drive into the usb 2 port
the hd format if full 1080p or 3d format.it only faults when the nas is used
thanks
sorry the nas is run with homeplugs 500mb
wifi or wired network...?
Oops, missed the homeplugs - should be easily fast enough!
[Edited on 11/11/12 by jonrotheray]
Which Dlink is it?
I have found updating the firmware on mine sorted alot of problems
its the 320 will look for updates
Homeplugs are in theory fast enough, but I found them far from stable enough to stream hd video. However, it's a simple enough proof, temporarily connect them via ethernet and retry the same video. If it skips, then you know where the problem is.
how many homeplugs are on the network and whats the distance it covers, as performance of homeplugs are depandant on distance and interfferences (mcb's, lightning protection, etc...)
