Which panels to get ?
the moa 2 - 10/12/05 at 12:53 PM
Hi i have a luego locost with a luego locost scuttle which is about 250mm high i need to get a new nose cone and bonnet and wanted to know which ones would fit .
I know Stuart taylor is book based but unsure who else.
Also could anyone measure the height of there scuttle/bonnet as i need to mae sure it would clear my R1.
Oliver Jetson - 10/12/05 at 05:16 PM
Silly question but how about goin to Luego for your body parts?
the moa 2 - 10/12/05 at 05:20 PM
Yes i know it is a stupid question i probably will get them from there but what i really want to know is how high it will be and whether it will clear my R1 which i have been told in the BEC forum that it wont.
rusty nuts - 10/12/05 at 07:43 PM
Have you tried putting your original nose cone on and running a string line between the nose and the scuttle ?. That way you will see if you need any extra height and possibly save you some money
JohnN - 10/12/05 at 08:15 PM
The Luego velocity nosecone is one of the tallest - See this thread for dimensions
[Edited on 10/12/05 by JohnN]
the moa 2 - 10/12/05 at 11:26 PM
Thanks for that i think i might need that height after reading some posts on R1 engine height.
Triton - 10/12/05 at 11:30 PM
Just because people say their bodywork is for the book Locost doesn't mean it's interchangeable from one firm to another...it all varies quite a bit.
the moa 2 - 20/12/05 at 08:16 PM
So you think that stuart taylor's wouldnt fit or the GTS stuff wouldnt fit even though they are book chassis's ?
Deckman001 - 20/12/05 at 08:19 PM
Probably not as straight a swap as you might hope, this does not mean that they won't fit, just that you might have to mod them a tiny bit to make them fit like a glove
Jason
scotty g - 20/12/05 at 08:44 PM
The GTS panels are taller than most but so is their scuttle so you would need that as well i think.
Surely you could knock up a bonnet bulge to make the lower bonnet fit?
Triton - 20/12/05 at 09:42 PM
I meant you won't be able to mix n match parts from different people...so if you get MK it all has to be MK.....same goes for GTS etc
