my footwell seems to get really hot, particularly at the top, I've fitted heat insulation sheet to the inside and outside of the sides and to the
outside of the top, this has reduced it, but the top is still really hot. The top of the pedal box is alloy unlike the rest which is steel sided,
I've now added a layer of fibreglass sheet to it and another layer of heat insulation sheet and yet it still gets hotter than the sides.
I'm thinking of changing the top to a different material, carbon fibre, steel or stainless, any other suggestions appreciated. On a similar note
the underside of my alloy dash seems to get rather warm as well...
Have you added heat insulation to whatever it is thats getting that area warm, rather than insulating the area that is warm?
I did have my headers lagged, but the downside is that as I have a stylus and the exhaust runs through the sill it is strongly advised against, it's a big fire risk
What about something reflective?
I've used this stuff
and it seems to work elsewhere, I'm thinking that some of the problem could be due to the alloy as it conducts heat easily, would another
material work better?
Dunno if you've already considered it, but having some vents for the hot air to exit would probably help. Could you do some Cobra-style exit
vents behind the front wheel arches, or something on the top of the rear of the bonnet?
and/or some ducting/channelling inside the engine bay to deflect the hot air down or sideways?
. A couple of vents at the back of the bonnet or in the side of the engine bay should help the heat get out, I found it tends to go down the gearbox tunnel rather than where I try to deflect it to though.
Don't think adding fibreglass sheet will actually help the issue as it will soak up the heat.
Unfortunately in my experience, Furies et al suffer quite badly from heatsoak in the foot compartment and I'm not sure there's much that can
be done about it other than to fit aircon.
S
PS Yes - lagged headers in a Stylus/Fury/Pheonix is a big "no no"
FWIW, I've drilled vent holes in the bottom of my pods...not noticable from the side as they're underneath
Hassle but what about some old PC fans or summat in there to duct some cool air over your tootsies?
James
Ceramic coating on the manifold and exhaust? Supposed to reduce temperature a fair bit. Never used it myself so cannot comment how effective it is.
I was thinking of adding vents to the outside of the car that I could open and close (in the area beside my feet), maybe with a push-pull cable or similar arrangement. High-speed cold air rushing in there should do the trick...
Originally posted by Humbug
Dunno if you've already considered it, but having some vents for the hot air to exit would probably help. Could you do some Cobra-style exit vents behind the front wheel arches, or something on the top of the rear of the bonnet?
Is the footwell roasting when at speed or just when idle?
When moving above 30mph or so, mine's not too bad; I don't have *any* insulation on mine. Only reflective insulation is on the inside walls
of the removable pod.
Only time it was really really bad was when the manifold disconnected itself from the silencer
Second the ceramic coating. Is that not that expensive (in the states atleast), and will produce great results (assuming it is the manifold/exhaust pipess that are causing the problem).
When moving above 30mph or so, mine's not too bad; I don't have *any* insulation on mine. Only reflective insulation is on the inside walls of the removable pod.
The key thing for a Fury exhaust is you don't want there to be a hot spot (crack in ceramic coating, gap/thin exhaust wrap) as common agreement on the sylva list is that this will be the quickest way to set fire to the pod....
