What are people’s views of Emerald K3 ECUs.
Have chance of one reasonably priced, half the pre vat list price, would be to run a 1991 engine so no frills needed.
I’ve no experienc of Emerald only Megasquirt / Tunerstudio, so wondered how good / bad / indifferent they are.
Cheers.
[Edited on 15/1/20 by r1_pete]
My k3 has been in constant use since 2009 when set up by Dave walker in hot / cold / dry / wet weather summer and winter and never missed a beat.
After sales is very good, just ring them and they will sort you out. Just keep dry like all ECU's.
Cheers.
Cheers chaps, I’ll go for it, has to be better than 1980s EEC Technology too
Cheers chaps, I’ll go for it, has to be better than 1980s EEC Technology too![]()
The EEC 4 my engine used doesn’t have map capability, used maf air temp and tps....
The Emerald can be configured for a map sensor, which is the plan now, it has a few user defined ports so may also look into maf.
What car / engine are you putting the Emerald on?
If your referring to Ford EEC then the Emerald would no be "better", its only advantage is its laptop mappable.
Still trying to figure how MAP works, seems its a trim on top of TPS rather than instead of.....
