got a new set of injectors for my ZX and gonna fit them this weekend if it stops raining.
anyone done these before? any tips on fitting?
cheers
duncan
Make sure you use the correct socket as I've seen a couple of of broken ones, normally the leak off pipe connectors. Replace the leak off pipes and cap even if they appear to be in good condition . DO NOT bend the injector pipes to get clearance, take them off if needed. Fit new sealing washers . Probably worth changing the fuel filter whilst your at it.
