Peugot 206 Cabriolet
MikeLR - 17/3/10 at 05:02 PM
Youngest daughter "fancies" a 206 Cabriolet,
does anyone have any thoughts on the matter, any good? known faults?is the closure of the roof reliable?etc.
Mike
blakep82 - 17/3/10 at 05:06 PM
mum has a 307cc. awful car.
in a 20 minute drive you get just about every error message you can imagine on the screen, apparently theres no replacement exhausts except proper peugeot ones, which cost a fortune. roof's quite clever, and is about the only thing that work properly on hers. its tried to kill me a few times but that was the pedal getting stuck under the carpet, but i do find that if you roll up to a roundabout in 2nd, see a gap and decide to go for it, you put your foot down, and nothing happens. by this time cars are coming at you pretty fast and its too late to go or stop.
hers has a lpg conversion which might be the cause for many of the problems though
[Edited on 17/3/10 by blakep82]
r1_pete - 17/3/10 at 06:15 PM
I had a 02 206 from new, worse car I've ever owned, poor panel fit, water leaks, pedals sticking under the carpet, interior squeeks and rattles.. the handling was also pretty poor for a small car, very front heavy, it was a diesel mind...
If she must have a convertible, an MX5 would be a better buy, a hardtop is available too.
speedyxjs - 17/3/10 at 06:59 PM
I learnt to drive in a 206. Hated it. Had all sorts of electrical problems and the brakes stuck on while i was driving it.
Then my mum brought a 307 and that suffered exactly the same problems.
rayward - 17/3/10 at 07:13 PM
really limited headroom, front and back
electrical gremlins !, also had a gearbox input shaft bearing fail at 26k miles
Ray
perksy - 17/3/10 at 07:18 PM
The 206 convertible has a known problem of the metal roof not closing correctly (stops a couple of inches short)
Also problems with water leaks due to poor seals on the roof
*If* She fancies a convertible an MX5 would be worth a look, Just beware rust
Just found a nice MX5 on an 04 plate for a Mate BUT some of the others We looked at had fairly serious rust issues considering how old they were...
MikeLR - 17/3/10 at 07:41 PM
I suggested the MX5, but her words were - "what if I cant get the roof up if it rains !"
Its better having a bit of difficulty closing a Rag top than having a motor/selonoid fault.
Mike
blakep82 - 17/3/10 at 08:32 PM
by the sound of things, same goes for the 206...
speedyxjs - 17/3/10 at 09:06 PM
There are plenty of other convertables with electric roofs. Doesnt the MGF have an electric one?
morcus - 17/3/10 at 09:19 PM
My dad had a 3 door 206 2.0 diesel and it was a brilliant car but he had to borrow an entry level one whilst it was being fixed and it was terrible.
On Vauxhall Calibras the boot can only be shut by holding down a button and it takes quite a long time, so you might want to check if the 206 has anything simillar. Your much better off with an MG or a Mazda I would've thought as you don't get any boot space with the roof down, and you'll have serious problems when the roof brakes.
Have you considered a C3 Pluriel? They drive well, have a decent amount of space inside and If you keep the bars in place the Roof is up at the touch of a button. You can also use it almost like a conventional hatch as the two piece tailgate opens fully. Its Probably based on a 206 as well.
iank - 17/3/10 at 09:52 PM
Mike
You have to stop in either car to raise the roof (I've spoken to people who think you can press the button at 70mph on the folding metal ones )
When I was a passenger in an MX5 putting up the roof seemed pretty simple.
You can now get an MX5 with an electric hardtop if she's buying new.
02GF74 - 18/3/10 at 01:47 PM
coinvertible? MGF - much cheapness, probably not that much goodnessm but hell, it can't be as bad as the peugeot?
or can it!?!??!?!
