Anyone know a good place to get a sytec high pressure fuel pump with JIC/AN fittings (-8) inlet and (-6) outlet. need as cheap as possible, cheapest
i've found so far is about £60 but that is without fittings.
Come on guys, pull one out the bag!
Not exactly what you want but this guy will make the correct kit up for which ever Sytec pump you choose, just need to know the threads
http://cgi.ebay.co.uk/AN-8-Cosworth-Bosch-044-Aeroquip-Fuel-Pump-Adapters_W0QQitemZ160413922429QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?ha
sh=item25596a347d
