Any one know were it is ??
The hand book says in the passenger footwell, but only on certain models
and mine appears to not be there ??
regards
If you mean the rollover cutoff thingy, I got mine from an older Mondeo and it was behind the carpet going up the side of the passenger footwell - I
had to cut the carpet to get at it. Not sure if it would be the same in an '08, but may be worth a look?
Simon
non of the diesel mondeo's have got one.
Thanks, as i have just found out,
apparently its ECU driven
oh Fu**
Were is the diagnostics plug, is the next query ??
It should be above your right shin when sitting in car. It's in a black plastic housing which slides down to expose the socket.
HTH
Thanks, but its not on mine !!
