As I desperatly need to find it !!
As my car is a diesel, they dont seem to go down the OBD11 route,
I might have to call ford, and spend ££££££££££, i dont have
regards
I had a 55 mondeo and I'm sure the aa man went under the cowling on the drivers side down just above the pedals. When I had a problem with my
crank position sensor.
Maybe different on the new one though.
Rich
Like here
[Edited on 25/3/10 by RichardK]
usually under the dash, enother favorite hiding place is under the trim below the handbrake lever.
Paul
Should be within reach of the drivers seat.
drivers side,right hand off the steering wheel in the roof of the pocket in the dash,
whats the problem ?
Thanks guys
the problem is it wont start, but the recovery guy (a friend) drove it on to the flat bed, and i new it was running about a month ago when another
friend viewed it
Regards
there it is, at he top of the locker behind a little door,
Shame its not OBD2 though
thanks for your help
regards
If made after 2004 by european law diesel cars must be fully EOBD with a standard 16pin OBD II connector, it will probably be on the CAN
protocol.
[Edited on 26/3/10 by britishtrident]
