just looking at the classes for hillclimbs....
what class would a locost (road legal) with a blade engine go into???
looking at joining the newquay motorclub...
cheers
barry
Does it have reverse and a windscreen?
Wyn
cheers
barry
it has no reverese or windscreen...
i am 18stone
Boggle 'reverse' it could have who knows, u2u
Hi most venues would put you in race class with aeroscreen if car has mot reverse should not matter ask club members
Technically with no reverse it is not road legal (from a MSA perspective) so it will be something like B7
From the 7Oaks regs
Category B: Modified Limited/Specialist Production Cars (S.10.10.3/4)
(excluding Group B Sports Cars, GT1 Sports Cars and World Rally Cars)
7. Up to 1400cc
8. From 1401cc to 2000cc
9. 2001cc and over
Hi
Yup as per the last couple above.
It was changed for this year to - all roadgoing classes require reverse gear.
But it will for your IVA if you're building it as a road car anyway.
Most of the country requires a screen too - but not all, especially down south, so check with a local organiser on that one.
(If this changes to one requirement nationwide it'll probably be to No Screen rqd, possibly as soon as next season)
If you're not building a road car, then build it to Mod Prod regs anyway, just ensure you build in the right spec roll cage and 6 point belts in
that case.
If it's a road car it'll just need a diagonally reinforced roll hoop, with back stays and 4 point belts.
You'd probably end up in modified although that would be a bit harsh for a road going car and I think we'd turn a blind eye in the Welsh
Championship.
Wyn
There could be very little difference between Roadgoing and modified Locaterfields this season, now that roadgoing can run 1b tyres. You'll be more competitive in roadgoing but it will mean you should run a reverse box, I suspect they'll be checking more thoroughly now that the regs have been revised.
quote:although the Midlands Speed Championship has reverted to 1A apparently!
so will an aero screen count as a screen???
i only have an entry level liscence and i know that for some classes you need a full liscence....im fitting an electric reverse for now.......
