My mate at work has a BMW e36 1.8 coupe. He's driving down the road goes to squirt water on the windscreen and the car suddenly looses power. Any
ideas what might cause this?
I can't see any relationship between engine and washer pump
A short circuit on the washer pump circuit?? Coincidence??
Leak from a hose onto something electrical?
Electric short from pump motor to something engine critical (fuel pump, EFI)?
Or electric short on wiper motor?
Mike
Possibilities:
1. a faulty pump taking far more current than it should (e.g. a bearing is dry, or it's partially blocked). I'd expect a fuse to blow
though.
2. It's squirting water over something in the engine.
In other words - what they said above!
well i think i'll have to have a look and see what i can find.
Same engine is used to move the car and pump the water
So , it is normal ( for a BMW)
Gerardo
drain the washer bottle and then try it..........
Good plan... except most washer pumps don't like to run dry.
Might be worth trying for a very short time, e.g. 10 seconds.
[Edited on 23/4/10 by David Jenkins]
Can a bulb be connected into the circuit in place of the washer pump - just to form a circuit and see if the car still loses power. Might be safer than running the pump dry during testing
The pumps earth has corroded and the pump is finding an alternative route through something important like the ECU, fuel pump, sensors etc
its much more simple than that.
The guy drives a BMW. They can't do more than one thing at once, such as push the accelerator pedal and also squirt the washers. Same reason why
they can't do the steering and indicating at the same time
Someone has plumbed the washer hose into the inlet manifold thinking it was a vacuum pipe. Seen it done !
I think it's a German car thing "balidey", same applies to Jerks in Merc's
The guy drives a BMW. They can't do more than one thing at once, such as push the accelerator pedal and also squirt the washers. Same reason why they can't do the steering and indicating at the same time
