Hi,
Found this whilst looking for a cure to the wife's tintop. It list all manufacture's recalls to date. So if you have a problem, and no one
else can help......
http://www.vosa.gov.uk/vosa/apps/recalls/default.asp
Ford Mondeo, 17.2.04 to 11.3.04 models:
"There is a possibility of unexpected braking"
I suppose I'd rather my car stop at random than go flat out at random
I suppose I'd rather my car stop at random than go flat out at random![]()
Oh yeah!
Apparently some of those Toyotas couldn't be turned off while it was moving, or knocked out of gear so you were kind of stuck
Oh yeah!
So what is the deal with recalls?
Assuming you buy a 5-10-15 year old car. At some point it was supposed to go under a recall.
Can you take it to the manufacturer to have a look at it?
How long does recall work for?
If I was asked to check if a recall repair was done I'd have a look for free at least
Also I persume a recall lasts forever, as if there's a problem with the brakes or (in the case of those Toyotas for he who has been living under
a rock
) the accelerator it doesn't suddenly get fixed on its own if you don't know there's a recall and thus leave it for years
Also I persume a recall lasts forever, as if there's a problem with the brakes or (in the case of those Toyotas for he who has been living under a rock) the accelerator it doesn't suddenly get fixed on its own if you don't know there's a recall and thus leave it for years
Good to look at donor parts, found one thing to check on my front calipers, although I don`t think it is an issue with mine.
Darren
Recall periods are determined in this country by the manufacturer and VOSA. The manufacturer tells VOSA amount of vehicles concerned and VOSA gives
them a suitable time period to complete the repairs.
Bear in mind though that a "reacll" doesnt nessecarily mean you will get a letter to take the car back, alot of them are to be carried out
during routine service work.
My new transit has just been recalled for a turbo oil feed pipe
Ford have mad a million transits and they still got it wrong
