Over the past few months i have been experiensing a very faint knocking from the osr on the tintop when goin over bumps (even small ones), that has
been slowly getting worse (more frequent rather than louder). I originally put it down to the exhaust hitting something as it used to disappear when
the car warmed up.
As it is now doing it all the time, i have just been out to look at the exhaust but it is all fine. What i have noticed is that the osr shock is
making a hissing sound when i bounce that corner and i can also hear a faint knocking. The thing is that the rear shocks were only replaced a year ago
and have only done about 7k since. Surely the shock cant have gone in such a small amount of time?
New damper required.
Hissing? Is it more of a squelching as the oil flows through the damper?
Are you sure you dont have a dodgy bush somewhere? (or loose top mounts!)
Gas shocks can hiss when compressing
Depends if you have a oil one on the other side! Most shock manufacturers sell both types for the same car.
Sometimes the rubber boots (if fitted) can hiss as air enters & exits, which is normal. A noisy shock will normally leak
The hiss isn't the main symptom to consider it is the click ---- if the bushes are OK and tight then any clicks or clunks usually indicate and internal problem in the damper. If you then consider the hiss/squelch noise only coming from that particular damper it points pretty conclusively to a failed damper.
Thanks for the help guys. Iv been to the garage that did the work and they have said it is still covered by warrenty (was fitted last July) so should
get it sorted for free
hissing? 's normal if it is an AC Cobra or Dodge Viper.
