What does anyone think?
Personally I think the adjustable wing is a bit of a stupid idea. I know the car in front has the advantage by virtue of driving through clear air but
surely then the important thing is to be in front
I think giving the person behind an artificial advantage is just going to make for a very boring season......
Why don't they just go the whole hog and give any driver out in front by more than 20s an automatic drive through penalty? It would also make
races closer but it would have nothing to do with the core elements of F1 IMHO.
Personally I'd like F1 to be a race. I quite like the double diffusers, f-ducts etc etc. However the idea that a "rear wing adjust
switch" gets turned on after two laps and then you can activate it at certain bits of a track? Seems a bit forced.....
Personally I'd also get rid of blue flags..... Why should cars being lapped have to move over? Still track position they're giving up.....
The modern 'travelling circus' F1 is rubbish.
Remedy is simple.
Get rid of aerodynamic aids.
The public are not bothered whether the cars go around a corner at 70 instead of 110mph!
They want to see racing!!
The answer is to allow aerodymaic aids that dont distupt airflow as badly.
(ground effects, the famous brabham fan from the 70s, etc etc) Im sure the hot shot designers could come up with a million and one new ideas to create
downforce that didnt disrupt airflow as they do now.
Remove all rules except car min weight and engine size. Let the quickest (reliable) car over the distance win!
It is tempting isn't it
We'd have to have some rule where they're not allowed to strip it down between races, so the car that does the last race is effectively the car that starts the first race. That'll enhance reliability
(ground effects, the famous brabham fan from the 70s, etc etc) Im sure the hot shot designers could come up with a million and one new ideas to create downforce that didnt disrupt airflow as they do now.
minimum 6 pit stops per race
no rear wing
skinny back tyres
big front wing
fat front tyres
no rear wing
skinny back tyres
big front wing
fat front tyres
oooh noo fwd drive f1 car the world would end
but i thought it would be all on the braking into corners but if you braked too late you would have no traction out of the corners
i like the idea of several pit stops ther usually a disaster or two when they do a round of pit stops
The problem with pit stops is success becomes reliant on the strategy guy, the mechanics and a bit of luck. I'd rather have the driver or, if
not him/her, the car.
Would be interesting to mix things up by having them race with another (suitable high speed) class.
My 35ft wide car is going to walk it if I get on pole
Ah! But your 35ft wide car would never get pole!..Imagine hustling it round Mirabou ? Or going flat at Eau Rouge
i agree you don't want some bright spark guy in the pits deciding the race but if you have enough pit stops it should screw him up
We should start a series in the style of the old touring cars rule, and just have a length and width limit. Anything goes as long as it's road legal.
Give the cars really poo brakes.
