as above, heres the linky, impressive product range...
http://www.shop4fasteners.co.uk/acatalog/
no but i like the look of those bonding fasteners i`ve never seen them before!
so ill be the test order then?
I`ve used them twice, no problems all Ok but their couriers WON`T leave without a signature, you have to rearrange a delivery time, Dennis.
if you write a note with the tracking number and instructions where you want it to be left and print your full name and sign it and date it that
should be enough but then the problem is if the item gets taken you wont get a replacement! i work for FedEx uk even if you sign for it you can steel
claim you didnt get it a signature means fuk all as its the couriers word against yours!!
they've even got the M3x10 stainless countersunk's I need...
but I'd need to buy 500 - I only need 8
M3 x 10 mm try here
http://www.directa.co.uk/site/scripts/product_browse.php?product_id=19766
^^ thanks but I'm really after stainless ones (A4 for preference)
Couldn't find exact match, but how about this
http://www.namrick.co.uk/acatalog/Home_Metric_Stainless_Countersunk_Machine_Screws_57.html
or you could try here
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=1583578
[Edited on 25/6/10 by scottfraser]
I used them about a year ago and if memory serves me right I thought they did smaller quantities then than the current full boxes only.
Other than that no problems at all.
Mal
