Hi Guys, could someone explain wheel offsets and sizing if they have a minute,
also, could someone in the know let me know if these wheels,
ebay
would fit a mk1 mx5?
they won't fit they are ford PCD of 108
MX5 is 100 i think
this explains it quite well: http://www.carbibles.com/tyre_bible_pg4.html
PCD notation
Stud patterns and PCD values are typically listed in this notation : 5x114.42. This means a 5-bolt pattern on an imaginary circle of 114.42mm
diameter.
http://www.carbibles.com/images/wheelpcdspigot.jpg
An image wrt circle that touches each stud , measure the diameter this is the PCD.
On a 4 stud hub or wheel you can measure diagonally across 2 from the centre of 2 studs
[Edited on 23/7/10 by snapper]
thankyou very much guys thats cleared it up for me,
