I am cracking on with the locost trailer transporter project.
I need to get it finished and moved before the pikies come back around
What to use for the decking ?
needs to be cheap-ish and able to with stand the weather.
your ideas please.
Plywood? External grade should do the job - marine if you got the monies.
I've used Stirling or is it Sterling board on my trailer. Every so often slosh some creosote over it and when eventually it rots replace it. Its very cheap and durable. I have thought of but never done it is to place a piece of galvanized 1mm steel over the top which would extend its life many times.
Weld some angle in for the tyres. Thats all you need
I have ground the galv of where ive been welding and doing it out side.
Some of those aluminium ramps you can get? Bolted down?
might not be totally locost but for a do it once job this ali punched decking seems a good price £63+vat 2500mm x 610 wide punched decking
What about some of those aluminium ramps you can get? Bolted down
Wooden tanilised Decking works......doesn't make it to flashy ....
If its to fancy it will disappear....trust me on that one
Isn't welding galvanised a no-no?
my phone went a bit funny
Galvanized wire mesh on mine, with aluminium sheet where the tyres sit :-
