As above.
Basically is this possible? E39 5 series auto with tiptronic. Is it possible to make/buy some paddles and some how wire them into the + and - on the
selector?
Dan
This is a subject that interests me. From what I have leaned so far you would probably need to install an aftermarket gearbox controller, after which
the paddle wiring would be easy.
Do you know which make and model of gearbox it is?
Not sure. BMW i assume? Unless they out-source their gearboxes???
Dan
Well you need to find out if you want to pursue this.
Shouldn't be too difficult, I did it with Jaguar recently, bit of googling and some cross referencing.
Possible candidateslinky
linkly
ZF gerabox?
i know someone who did this to the 5 series was with oem parts too
Any more info on that one beaver?
Dan
