Daughter's Vauxhall Astra estate 5 door 1999 S reg the airbag light stays on all the time - anything obvious I should start looking for - any
advice appreciated.
connections to seat belt pre tensioners maybe ?
Ray
Check the connectors under the seats to the seat belt pre-tensioners. Poor connectors there is the most common cause.
More likely to be the 'squib' on steering wheel coluum- very common fault on vauxhalls.
Thanks for the replies chaps - very useful - I'll take a look when she brings it over at the weekend.
Could you just clarify a couple of points? The seat belt pre-tensioners what do they look like - or is it just the electrical connections under the
seat I need to check?
And the squib? not sure what bit this is - do i look under the plastic housing around the column or something around where the steering wheel
attaches?
cheers
This is an astra squib, not under the sea, its under the steering wheel cowls,
http://cgi.ebay.co.uk/Astra-G-Mk4-1998-2004-Steering-Wheel-Airbag-Squib-/250657976021?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=i
tem3a5c612ed5
tony
Mmm local word here for firework is squib (pronounced skweeb)
The seatbelt pre-tensioners are in the buckle and pull the belt tight in the event of a crash. It's just the connectors you need to check
though.
The squib is behind the wheel and connects the airbag (rotating) to the column (fixed). You won't see any problem with it though and needs
diagnostic kit to test.
DON'T start messing with the airbag/sqib though untill the battery has been disconnected for at least 20mins.
adrian
