My daily runner, has developed over the last couple of days, a little prob, and looking to the collective to give me some pointers so that I do not
have to bend over for some garage bills.
Fiat cinqucento 1.1 sporting and the clutch will not engage fully. ie pressing the clutch in with car in gear puts a small pull on the car.
Makes changing grears very clunky and putting it into reverse very noisy.
Ideas are clutch cable adjustment, or is it a new clutch?
Craig
Adjust the cable first. But will probably snap soon as they do go, its a known weak point. Had to do a couple of cables on mine, but never had to do a
clutch.
I would buy a cable now and keep it in the car (like I do)
Either clutch fingers wearing/breaking or realese bearing failure or oil contamination (all gearbox out and new clutch etc) or cable starting to fail
(known to break at the pedal end).
adrian
thanks folks, manged to get it home last night using a couple of the gears.
quickly nipped out to garage with tools and a lamp and adjusted the clutch cable.
Now works perfect..thanks for the notes.
Craig
