Changing the steering wheel in my daughters Ford KA - cant quite see what the bolts are that hold the airbag to the steering wheel. Can anyone tell me
the type and size please?
Mark
They may well be some form of security screw - I can't speak for Fords, but I did have to buy some special screwdriver bits to undo the airbag on my wife's Daewoo Matiz.
If its the same as a mondeo it will be a torx bit, quite small but not sure exactly what size.
If its anything like the Mk4 fiesta then you have to remove the ignition shield and remove the bolts from the back. The heads are an odd size, too big
for a 5mm socket and too small for a 6mm. I managed to find an old socket that was a good fit but I couldn't see what size it was.
One thing you must do is to disconnect the battery and wait for at least 2 minutes before starting work.
Hope that helps.
Duncan
Hope that helps.
Duncan
The heads are an odd size, too big for a 5mm socket and too small for a 6mm.
7/32" Hex head I think.
Try 5.5mm , and yes it does exist
5.5mm socket and its a myth that you have to wait to work on airbag systems when the battery is disconnected
