cheers
No, because the switch is in the wrong place.
Howver you need to establish if your switch is normally open and closes at it's hot temp or the other way around. As it will make a difference on
the wiring.
Roger
Put the switch here, so you are using it to energise the low current coil in the relay, and the relay contacts handle the high curent requiement from
the fan.
Image deleted by owner
whilst we are on the subject... does anyone have a diagram for the same thing but with a fan override switch, so you can turn the fan on and off from the dash, without needing the temp to get high enough?
Yes, just put it in parallel with the rad swich like this:
Howver you need to establish if your switch is normally open and closes at it's hot temp or the other way around. As it will make a difference on the wiring.
Roger
Is how I had mine
Just add a switch a cross the temp switch for over ride
Or if you have a 3 terminal switch you can do dual fans
[Edited on 18-9-10 by ken555]
its my understanding that the switch closes when reaching 95 degrees and subsequently supplies the fan with 12 volts
