Any one got access to a Lotus elite 1971, got a neighbour who needs 2 gas struts for the bonnet (rear)
Need to know the closed and open length.
I appreciate its a long shot but this site usually come up trumps.
Cheers Pif
Can't help with the question but, are you sure it's an Elite? Early Elites were made 56-63 then the later one from '74 and both front
engined.
adrian
ps. sorry about Sat; I thought it was some numpty trying to wind me up.
it may be a 74 although it has a 71 plate on. It could be a private plate.
saturday, saw your car in the car park and kept an eye open for you all day. Then I saw you at the lights through the double speed cameras where the 2
bikes almost stalled off the line. then tried to catch you up after you blasted them both away. Hovered next to you at the iron bridge to get your
atention.
cheers chris
saturday, saw your car in the car park and kept an eye open for you all day. Then I saw you at the lights through the double speed cameras where the 2 bikes almost stalled off the line. then tried to catch you up after you blasted them both away. Hovered next to you at the iron bridge to get your atention.
cheers chris
Figured it out when you caught up... and called me a hooligan!
Measure the open and closed lengths and end fixing types --- most motor factors can look up a part number from that info alone.
Otherwise any of the classic Lotus specialists can supply.
Just guessing, but I don't think he has the originals.
