EXHAUST FLAMER Westfield, Dutton Lotus 7 locost kit car on eBay (end time 17-Oct-10 22:09:05 BST)
do you think my neighbours will mind
(only joking i AM NOT getting one)
lol my car does that any way
arn't they illegal?
lol my car does that any way![]()
fit a pair of carbs you get that effect as standard when backing off
To complete the flamer installation you will also need the following,
Old or new 12V Ignition coil
Spark plug lead,
Spark plug,
Switch,
Wire
Dont need it on the locost you get lots of free flames wen you blow through carbs!
Would it work on my Turbo diesel Astra?
Chav!
Did i ever tell anyone that i managed to split my backbox on my pickup truck on a backing off?
hehhehehe
It splitted like a mushroom along the weld
SO if this works on trucks.... Intresting most trucks are Diesel there for implies this works with diesel.
It must be pretty impressive to get diesel to light with a spark plug!
LOL I wonder if you can install it alongside one of Exhaust Pipe Turbo Whistler - BMW 1 3 5 6 7 8 X3 X5 Z3 on eBay (end time
23-Oct-10 19:00:58 BST)
Flames AND whistles!
Used to have an old Yamaha SR 500 motorcycle (road going, slightly chopped looking variant of their XT 500) which had a single cylinder and a very
complicated carb. I fitted an after market exhaust which ran cherry red as it came out of the cylinder..... If you slammed the throttle closed at full
chat it would send out a sheet of flame with BANG like a shotgun going off... you should of seen the coppers jump in Parliament Square ( despatch
riding at the time) when I rode round it.....
keith
Does anyone know if it is IVA'able? Id like to fit one to my car?
Its not in the manual so they cant test it
Originally posted by jack_t
Its not in the manual so they cant test it![]()
