Morning all,
Does anyone know where I might be able to source a small quantity of PTFE or Teflon paste that is used for sealing threaded pipe connections? I
specifically after something that is rated for use with gaseous oxygen carrying pipes, which rules out the standard plumbers stuff that is commonly
available?
try pipeline center part of plumb center or bss if you have one near by.
hth rob
Originally posted by bigandy
Morning all,
Does anyone know where I might be able to source a small quantity of PTFE or Teflon paste that is used for sealing threaded pipe connections? I specifically after something that is rated for use with gaseous oxygen carrying pipes, which rules out the standard plumbers stuff that is commonly available?
available?
screwfix?
dave
