I cam to start my tin top today after being stood for a week. It didn't even try to start. I jump started it from another car but it wouldn't turn over until I got someone else to rev the other car quite hard while I started mine. It's been fine since but if the battery was that flat, will it be damaged beyond repair?
I had it with mine when the alternator shorted itself. The battery was and still is fine in my case.
Could be either way. The wifes cooked the alternator two weeks before xmas after a flat battery.
You could try an intelligent battery charger
CTEK XS3600
or
Oxford Oximiser
or
Optimate
or
Accumate
I would not be worrying about the battery so much as if the car has a fault that has caused the battery to go flat. If so this will eventually kill
the battery even if you have got away with it once. I would be tempted to disconnect it and measure the residual current drain with a DVM.. For a 35ah
battery over a week to be completely discharged only needs 200mA load (i.e. 35/(7*24))..
Dan
Slow charge the battery for 24hrs, let it rest for a few hours then test the volts drop under 200amps load.
I bought a car that had been standing & the batterey was totally flat, it was fine & I used it for 7 years & once in that time it went flat again due to lack of use but again it was fine & was still as good as ever when I sold the car!
When you jump a car battery it's better to connect the two together and let the running car charge the flat one for ten minutes before trying to
start the flat one by revving the nuts off the jump car.
I had a battery which died and got stuck in the shed after it was replaced. I put the
Optimate on it and it went into desulphate cycle and after 3 days it charged up. It ran on my daughter's car for two years before she sold it.
Surprisingly those jump start cables the connected between cigar lighter sockets work pretty good if you give them a few minutes to work.
Of course nothing beats real pro HD jump leads and a big battery.
Batery is fine after an over night charge still had to do the alternator in the snow ....
My guess was short trips to work and cold = flat batery and like you say the alternator didnt like the very flat batery.
Probably too late now but i wouldn't drive it until fully charged as Im sure you can knacker the regulator on the alternator from it working its knackers off trying to recharge a flat battery.
I remember something about making sure the electrolyte is topped up...
In my experience a completely flat battery (so called deep discharge) is a bad idea for lead acid batteries.
As previous posts say they sometimes recover taking only a small charge current to start with.
If it does recover you are lucky.
In my experience car batteries are able to survive a deep discharge better than a bike battery. I know the lead plates can buckle when deep discharge and short- perhaps because the bike battery is smaller the plates are closer together so buckling is more of a problem? But fundamentally deep-discharging non deep-discharge batteries is a bad idea.
