I need to paint the exhaust black on my Rotax Max kart .
What paint should i use?
Would prefer aerosol can spray.
The exhaust gets bl**dy hot as its a one piece 2 stroke system.
Last time i painted it the paint just burnt off when it got hot.
Any ideas?
matt
I've used BBQ paint on 4 stroke exhausts with some success.
HTH
Neil
Yep I used bbq paint on my lads ts125r, no problems so far, I used this stuff fyi, nice satin finish. Plastikote BBQ Spray Paint -
400ml on eBay (end time 05-Jan-11 15:51:07 GMT)
Rich
[Edited on 3/1/11 by RichardK]
not had much luck with the high temp paints on my 2 stroke exhausts they all tend to flake off eventually
We tufftrided our TKM and 125 ICC exhausts/expansion chambers
What about the stuff for spraying wood burning stoves might be the same as bbq spray but worth a look
I use halfords high temperature exhaust paint (aerosol) on my scooter, seems to work a treat.
How about bluing?
Give it a good clean with steel wool then spray with wd40, gives a good finish when burned off and easy to "top up" I have always done this with my 100's, rotax and gearbox karts.
