Looking at changing a Clio 1.9 Turbo Diesel CamBelt, Tensioners and other related bits at same time. Is it an easy job or not? How long should a
hobbyist mechanic take to do the job, its for the mother-in-law!!! Is there anything else to do at the same time whilst its in bits??
Never done one but the Book time is just over 3 hours
Not a bad job to do yes 3hr job but do get a belt kit
that has the top cam pulley as well as tensioner
and idler as cam pulley is prone to the rubber
section breaking away, dont half make a noise when it does
Have fun. Make sure you don't turn the engine over with the crank bolt loose , some of the Renaults have a floating crank sprocket, (no key)
1.9 clio will be keyed, MAKE SURE you change the cam sprocket but I dont think it comes in the kit - ive lost count of the number of these Ive seen with a sheared off key in the sprocket
