As title really, does anyone know the height of the RV8 and how much power the rear axle of late 70's triumph's can handle?
From www.boostperformance.co.uk
The Corvette LS1 engine measures approximately 25.25" long (Rover V8 is 27.5" ), LS1 overall height is 24-25" (Rover V8 is 25.5"
plus the carb and air filter or efi plenum, 29-30" or more), LS1 width across the cylinder heads is 20.5" (Rover V8 is 20" ). With the
T56 6 speed gearbox fitted the LS1 is some 3" shorter than a Rover V8 with a standard 5 speed gearbox. If you wish to purchase a custom hand
built, fully blueprinted engine to any specification feel free to call me. We also overhaul and rebuild standard engines with a few miles on them
useing approved GM tooling.
No idea about the axle, I've got one from a V6 Capri on mine.
Rear axle of TR7 variety is plenty strong enough - not sure if they were used on other triumphs though.
Thats good. It was the TR7 one i was thinking about. I read that they were all the same in the late 70' at least.
Originally posted by interestedparty
Don't tell me, let me guess, you are going to build a car based on a 2ltr TR7, and are going to change the engine at the same time.
